yogi's Avatar
Fuses
After the problem I had with my 25 amp fuse crumbling from age and effecting my fuel pump. Someone suggested replacing all the old looking fuses. I can find the 25, the 16 and the 8 amp fuses. What I can't seem to find is the 5 amp fuses. Does anyone know where to buy them? thanks,
Jerry Baer
87 Carrera Coupe
Old 03-01-2006, 08:22 PM
Retired Member
Charlie V's Avatar
I am having the same problem...
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 03-01-2006, 08:57 PM
Early_S_Man's Avatar
Porsche Crest
I haven't seen any in more than 10 years ... most dealers will tell you to just use the 8 Amp fuses. Reasonable solution, most of the time.
Aircraft circuit breakers are a foolproof solution, but extensive modification to wiring harness.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-01-2006, 09:05 PM
The Porsche part number for the yellow 5-amp fuses is 90017300690. In the recent past (within the last year or so) I ordered these through Pelican and they were $1.00 each. However I note Pelican is now showing them NLA on line, however you might call them and see if it is just a temporary situation. One could also call other parts sources such as Stoddards, etc. and see if they have the fuses.
Old 03-02-2006, 05:10 AM
rallyracer's Avatar
Went to a Porsche dealer near me. They don't show them available either.
1983 911SC-Sold!
Old 03-02-2006, 05:16 AM
Install425's Avatar
I have bought them a discount auto in FL
Rob,
88 911 Turbo
Old 03-02-2006, 05:17 AM
If ANYONE suggests using 8A where 5A was originally used.....regardless if they're the dealer or not...they are nuts and severely WRONG......
8A is 60% ( let me spell it out .... "sixty percent") higher value than 5A !
There is a REASON why 5A was used in the first place... !
Take it from someone who had a $3000 wire harness melt-down and a 4 month lay up for repairs.... due to stupidity like this by the PO.....
- Wil ( stronger language to follow...)
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-02-2006, 05:35 AM
Here in northern NJ I have had no problem finding yellow 5A German fuses at the local parts store. You guys have scared me into buying two packs. They are made by Buss. I'm sure any parts store can order them.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 03-02-2006, 05:46 AM
Volvo uses the same fuse type for their early cars. You might try one of their shops or someone who services euro cars.
Tony G
2000 Boxster S
Old 03-02-2006, 07:24 AM
JWest's Avatar
Try a web search for "Bussman GBC-5" or "Littlefuse GBC-5"
They seem to be readily available.
James
JWest Engineering
Old 03-02-2006, 07:48 AM
Wider is Better
wholberg's Avatar
this company sells them in bulk (i.e. for Pelican to buy)
http://www.allproducts.com/traffic/yanmg/Product-2005718123123.html
Wider is Better
Old 03-02-2006, 08:11 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Anybody found a good source for these? How about the pink one - 20 amps? Strange nobody carries these?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 03-08-2006, 03:46 PM
Wider is Better
wholberg's Avatar
www.littlefuse.com sells 5, 8, 16 and 25 Amp. in packs of 50. I could not find 20A GBC fuses.
Wider is Better
Old 03-08-2006, 04:12 PM
Autodidactic user
David E. Clark's Avatar
Looks like you can get them in Malta too!
5 Amp European Fuses
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 03-08-2006, 05:50 PM
vesnyder's Avatar
I found them at Stoddard's! But when I went to pick them up they had the 8 amp to give me, but they did have the 5 amp in stock. They also gave me the wrong gaskets?? - WTH
Vance
Old 03-10-2006, 02:09 PM
