front height adjustment
How far can you adjust (raise) the front ride height with the adjusting bolts on a Carrera before the car needs to have a new front end alignment?
"Charlie don't surf!"
Old 09-25-2012, 07:58 PM
Go-Kart Mozart
JAR0023's Avatar
I just raised my '86 from 24.25" to 25" at the fenders. My level only reads to a tenth of a degree and there was no measureabl change in camber. I had a smidgen (less than a 16th") change in toe. Measured with 22" long toe plates. Depending on where you are starting from I would think one could enconter different amounts of change.
I was confident enough to make the toe correction myself. If not I would have at minimum taken the car and had t checked. Some places will hang gauges and check for cheap if you ask.
J
Old 09-25-2012, 09:46 PM
