Elombard's Avatar
How do I know if I need spacer on Hi Torque?
I received my new hi Torque mini starter and it comes with a spacer. I have my old starter out and i tried to measure the difference between the two but its difficult to measure accurately and the spacer is only ~ 2 mm so its tough to eye ball.
Is there any other way to tell? I hate to chew up the ring gear with the wrong guess.
Surely this is covered in a thread but I could not see it with several searches.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-28-2012, 05:11 PM
Able to bench-mount and energize each, then mark reference points of the extended pinion gears?
Also confirm the teeth patterns are compatible.
Sherwood
Old 09-28-2012, 05:47 PM
Elombard's Avatar
I will try it, but again its only 2mm difference so its got to be a pretty accurate measurement and there are no really good straight edges to reference. Maybe I can measure down to a pencil mark on the bench.
Old 09-28-2012, 06:07 PM
Not absolutely sure, but it should be possible to bench-energize the solenoid w/o energizing the motor. If possible, the solenoid will extend the pinion gear out to its maximum extension.
Record the measurements from each starter, then compare with the distance between the starter mounting surface on the gearbox and the ring gear. The objective is to fully engage the ring gear w/o over or under-reaching it. BTW, a 2mm spacer represents pretty close fine-tuning.
Sherwood
Old 09-28-2012, 06:19 PM
Elombard's Avatar
I can energize the stock starter and the pinion come out but not the mini (it jumps out and spins), but I can pull the mini out by hand. They both appear t stick out the same amount, again difficult to measure ~2mm when there are no really good flat surfaces to gauge from.
Next I put both starters on two 2x4 scraps face down (on their mounting surfaces) and I was able to see that the Mini pinion sticks out slightly farther than the stock. So I am going with the spacer.
Old 09-29-2012, 04:43 AM
Excellent. Always better to confirm and not assume.
Sherwood
Old 09-29-2012, 08:57 AM
