Ball Joint/Wedge Bolt anti sieze
I assume I need to use anti sieze on the ball joint shaft and the wedge bolt but I can't seem to find a thread the is definite on this issue. Can someone confirm? It seems like it would help the ball joint shaft orient itself properly as the wedge bolt snugs up, but I can't say I have anything concrete to back that up.
TIA
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I oiled the ball joint shaft and never-seized the wedge bolt when i did mine.
The tolerance is tight....don't think you'll get much anti seize to stay on the ball joint shaft.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
