-   -   response by motronic to cat delete with o2 sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/708970-response-motronic-cat-delete-o2-sensor.html)
inaminit 09-29-2012 05:06 PM
Hello- If you have an 86 3.2 motronic managed engine with a cat delete pipe but with an o2 sensor-what is the response to the o2 sensor readings? I am wondering - will the motronic will adjust to the readings by altering injection timing or by going leaner or richer? If you run for an extended period with this setup-is there a downside? Thanks in advance.
plumb4u2 09-29-2012 05:27 PM
I'm no expert but the o2 sensor is before the cat so why would there be any difference?
SilberUrS6 09-29-2012 08:08 PM
This is the correct answer. Since the OXS is before the cat, having or not having a cat won't make any difference to the ECU.
inaminit 09-30-2012 05:43 AM
Thanks for the answers!
