response by motronic to cat delete with o2 sensor
Hello- If you have an 86 3.2 motronic managed engine with a cat delete pipe but with an o2 sensor-what is the response to the o2 sensor readings? I am wondering - will the motronic will adjust to the readings by altering injection timing or by going leaner or richer? If you run for an extended period with this setup-is there a downside? Thanks in advance.
Old 09-29-2012, 05:06 PM
plumb4u2's Avatar
I'm no expert but the o2 sensor is before the cat so why would there be any difference?
Justin
84 Carrera Targa
98 F-150 4x4
Old 09-29-2012, 05:27 PM
Banned
This is the correct answer. Since the OXS is before the cat, having or not having a cat won't make any difference to the ECU.
Old 09-29-2012, 08:08 PM
Thanks for the answers!
Old 09-30-2012, 05:43 AM
