Juggino's Avatar
Send a message via AIM to Juggino
How to change Glove Box door
Can anyone give me a quick guide how to change the glove box door?
Old 10-02-2012, 08:52 AM
ROW '78 911 Targa
timmy2's Avatar
Remove lower knee pad. (nuts under dash)
Undo 3 screws at hinge.
Reverse to install.
Old 10-02-2012, 09:10 AM
Juggino's Avatar
Sounds simple enough, thanks.......
Old 10-02-2012, 09:14 AM
Not quite that easy. The center screw holds the strap that surrounds the 'box' of the glovebox. Remove center screw and lower strap and box. Then there are actually 4 fasteners holding the door. Two are screws with backing nuts (have your socket/wrench ready so you don't strip the screw head, they will be tight!) and two are studs with nuts that you get after the 'box' is lowered away. Good luck.
Old 10-02-2012, 10:42 AM
ROW '78 911 Targa
timmy2's Avatar
You're right, 4 fasteners not 3. Been a while since I had mine out. Nice description.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-02-2012, 11:06 AM
DG624's Avatar
I had to remove the air vent to get to the nut holding the right side of the knee bar. To get the air vent out you have to remove the screw on the right and then the clips must be depressed (4 two top two bottom). It can be very time consuming and tedious.
Old 10-02-2012, 12:19 PM
rfloz's Avatar
Removing Glove Box Lid - Not So Easy!
Bob F.
1984 Carrera Factory Turbo-Look
Old 10-02-2012, 12:50 PM
