shift coupled problem
I just got a new shift coupler from our host. it moves in all directions alot.the black bushings allow the pin to move side to side and up and down. big gap between shaft and bushing.http://forums.pelicanparts.com/uploa...1349338803.jpg
http://forums.pelicanparts.com/uploa...1349338827.jpg can this be right they move more than the old one.i thought it was suppose to be tight? |
Normal.
Don't worry mate. |
search "coupler whisperer"
:D |
Yes, coupler whisperer. You will not be disappointed.
OP, PM ivangene on this forum and purchase a set of his bushings. Made a huge difference in my car. -J |
how does it tighten up shifting if its that loose?
J http://forums.pelicanparts.com/porsche-911-technical-forum/649265-coupler-whisperer.html?highlight=coupler+whisperer http://forums.pelicanparts.com/porsche-911-technical-forum/643711-eds-shift-coupler.html?highlight=coupler+whisperer |
+1 on ivangene's coupler bushing..made a huge difference to my poorly shifting SC. Now there is very little hesitation going up or down the gears.
+1 for the coupler whisperer.
thanks i will look in to that. the replacement i have will not due. thanks everyone....carl
