AC burnt out?
So i charged my AC system. worked for awhile but would often get a bird chirping sound in my vents. Sounded like the fan squeaking. Then it seemed like one speed went out and then another to the point where i smelled a burnt smell in the cabin and the ac stopped working completely. Compressor still works, defrost still works etc...
Any ideas? |
It sounds like your evaporator fan has died.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Sounds as if the evaporator blower was drawing to much current and the thermostatic protective switch in the air inlet duct (behind the passengers foot board) has failed.
Mouse, mice in the squirrel cage blower? |
will switch out the blower and switch and see...hopefully that works!
Evaporator fan or blower? Can someone point me to a particular part?
Before you replace your fan, check the resistor pack that is in the passenger footwell duct - these resistors are what control the fan speeds, and often burn up, esp if you have any rubbing of the fan which would cause extra current draw.
The evap fan is the one inside the smugglers box - if you have to replace it I suggest you get the keul fan upgrade; I just did this and it seems a worthwhile improvement. You don't mention what year car you have BTW. Chuck.H '89 TurboLookTarga, 340k miles |
Senior Member
Agree with Chuck. If the resistor pack is not passing power to the fan, then nothing is going to happen.
As well I have the Griffiths fan upgrade and its well worth it.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I have an 87 911 coupe. Thanks for all the help!
Before you do anything you may want to try this. It worked for me.
Drill a small hole in the top of the fan housing in the Smugglers box. Spray some WD-40 in the hole using the straw. I did this and the fan inside the housing started turning again. I have to do this about twice a year and then cover the small hole with electircal tape.
Smoke 1982 911SC Rosewood SCWDP # 0097 |
NP - the Griffiths fan update requires you to find the evap box from a an earlier year, like up to 86 I believe. I got my housing from parts heaven. You only need to change the top of the housing, so you don't have to disturb the evaporator.
The top/bottom housing clips well they are a different story - when I had my box apart I ditched those clips and put straps + springs around the housing to hold it together - works MUCH better and can be easily installed and removed with the evap + lower housing in place. Chuck.H '89 TurboLookTarga, 340k miles |
1988 Carrera
tpweiss9953: I just replaced my entire A/C system. If you need help I'm in Slidell, Eden Isle, and would be glad to help you out. I have the Resistor that I took out of my 88. We could plug it in and test to see if that is your problem
No time like the present to throw the whole system in the trash; it really is a joke
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
