Wheel size/ backspace/ offset
I have an 81 sc with stock flares running 15x7 front and 15x8 rear fuchs. I want to get a set of track wheels- 15x8 on all 4 corners (preferably minilite/ superlite/ panasport/ tre style w/ hoosier R6's).
I'm hoping you guys have some ideas about the appropriate backspacing/ offset (fenders not rolled and I would prefer not to) thanks! |
There's someone selling a set of four 15x8 Fuchs for your application in the classifieds,maybe you should contact him and get the info.Looks like a good deal as well for a beautiful set of refinished wheels ...
Cheers ! Phil |
I don't know about 15" wheels specifically, but I've run 8x16s in the front for a long time. The 16s need about 5.75" of backspacing to fit.
One data point... |
ET a little higher or lower cause increasingly more issues No matter what this is a very tight fit and using the shortest possible tires w/ aggressive alignment will help. |
thanks!
I have tried multiple times to run 8 fronts, no luck with SC flares
| All times are GMT -8. The time now is 05:17 AM. |
