ACH996's Avatar
Wheel size/ backspace/ offset
I have an 81 sc with stock flares running 15x7 front and 15x8 rear fuchs. I want to get a set of track wheels- 15x8 on all 4 corners (preferably minilite/ superlite/ panasport/ tre style w/ hoosier R6's).
I'm hoping you guys have some ideas about the appropriate backspacing/ offset (fenders not rolled and I would prefer not to)
thanks!
Old 10-06-2012, 11:36 PM
Northern Motorhead
wildcat077's Avatar
There's someone selling a set of four 15x8 Fuchs for your application in the classifieds,maybe you should contact him and get the info.Looks like a good deal as well for a beautiful set of refinished wheels ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-07-2012, 05:29 AM
IROC's Avatar
I don't know about 15" wheels specifically, but I've run 8x16s in the front for a long time. The 16s need about 5.75" of backspacing to fit.
One data point...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-07-2012, 06:40 AM
Bill Verburg's Avatar
thanks!
For and SC/Carrera body car 8" fronts want ET25-30, the lower the ET the more the wheel sticks out and the more lip issues there will be, the higher the ET the more the wheel sits in board and the more issues there will be there.
ET a little higher or lower cause increasingly more issues
No matter what this is a very tight fit and using the shortest possible tires w/ aggressive alignment will help.
Bill Verburg
Old 10-07-2012, 10:35 AM
ACH996's Avatar
thanks!
Old 10-07-2012, 07:57 PM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
I have tried multiple times to run 8 fronts, no luck with SC flares
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 10-07-2012, 08:00 PM
Tags
minilite , panasport , superlite , tre , wheels and tires
