CIS removal - engine out - 82 SC
Hi all,
I would like some advice on how to remove the CIS and runners the easiest way and without taking the CIS all a part in a 1000 pieces. I need to give the engine a nice cleanup under all the CIS stuff and install new injectors, runner boots etc. Thanks, Christian |
It all can be removed as one unit. Remove the two nuts from the base of each runner. Use a universal joint and extensions on your socket wrench. And remove the accelerator linkage. Then get a helper and wiggle and lift it up as an entire unit.
It works. I did it! |
There is also a bracket at the back that need to come off, it goes to the top of the accelerator linkage plate.
Thanks a lot guys!
Have a nice sunday! |
Christian
Would you take and post some pictures of where the metal CIS lines at the back and sides of the engine go? Thanks Lorne M. |
Timing is everything. Thank you for this thread!!!! Here I thought I was going to have a million parts laying around. Going to change the boots, o-rings, injectors, etc. on the CIS.
Of course I will take some pics.....do you mean the furl lines?
Yes, the fuel lines from the fuel distributor unit to cold start/frequency valve/ return lines
Lorne M. |
Pics to be posted tomorrow after work.
Late SC fuel line back side......
http://forums.pelicanparts.com/uploa...1349644236.jpg http://forums.pelicanparts.com/uploa...1349644248.jpg http://forums.pelicanparts.com/uploa...1349644263.jpg http://forums.pelicanparts.com/uploa...1349644276.jpg Tony |
I also have the engine and tranny off the car... The lines are not connected (the ones to the injectors) but everything else is.
http://i151.photobucket.com/albums/s...huko/CIS-1.jpg |
Here are some pictures. Let me know if you need detailed ones.
The SC CIS system is born a mess - hence my decision to remove it in as few pieces as possible - parting it would be like doing a 1000 piece jigsaw puzzle....jeez! http://forums.pelicanparts.com/uploa...1349715143.jpg http://forums.pelicanparts.com/uploa...1349715225.jpg http://forums.pelicanparts.com/uploa...1349715273.jpg http://forums.pelicanparts.com/uploa...1349715328.jpg http://forums.pelicanparts.com/uploa...1349715380.jpg http://forums.pelicanparts.com/uploa...1349715431.jpg |
Great Pics Guys, it is nice to see how our systems should look and as a bonus when we need to get behind out air boxes to check the cold start or frequency valve we know where to go.
Thanks again Lorne M |
| All times are GMT -8. The time now is 12:39 AM. |
