				CIS removal - engine out - 82 SC
			Hi all,
				I would like some advice on how to remove the CIS and runners the easiest way and without taking the CIS all a part in a 1000 pieces. I need to give the engine a nice cleanup under all the CIS stuff and install new injectors, runner boots etc. Thanks, Christian  |
			It all can be removed as one unit.  Remove the two nuts from the base of each runner.  Use a universal joint and extensions on your socket wrench. And remove the accelerator  linkage.  Then get a helper and wiggle and lift it up as an entire unit.
			It works. I did it!
	Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.."  |
			 ROW '78 911 Targa
			There is also a bracket at the back  that need to come off, it goes to the top of the accelerator linkage plate.
	Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.  |
			Thanks a lot guys!
	Have a nice sunday!  |
			Christian
			Would you take and post some pictures of where the metal CIS lines at the back and sides of the engine go? Thanks Lorne M.
	83 SC  |
			 PhD on Pending Projects
			Timing is everything.  Thank you for this thread!!!! Here I thought I was going to have a million parts laying around.  Going to change the boots, o-rings, injectors, etc. on the CIS.
	Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet  |
I second the request.  My lines were removed by the previous owner as a preventive measure when he stored the car...plus he soda blasted the lines... They look like new.  I need to install all this back in a few weeks.
			Of course I will take some pics.....do you mean the furl lines?
			Yes, the fuel lines from the fuel distributor unit to cold start/frequency valve/ return lines
			Lorne M.
	83 SC  |
			Pics to be posted tomorrow after work.
				Late SC fuel line back side......
			I also have the engine and tranny off the car... The lines are not connected (the ones to the injectors) but everything else is.
			Here are some pictures. Let me know if you need detailed ones.
	The SC CIS system is born a mess - hence my decision to remove it in as few pieces as possible - parting it would be like doing a 1000 piece jigsaw puzzle....jeez! ![]() ![]() ![]() ![]() ![]()
			Great Pics Guys, it is nice to see how our systems should look and as a bonus when we need to get behind out air boxes to check the cold start or frequency valve we know where to go.
					Thanks again Lorne M
	83 SC  |
