Eva
+1 |
Caveman Hammer Mechanic
I have a large port Webb Industries listed in the for sale section. If you are interested.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
A poor mans solution for a pop off valve is to leave the rubber boot clamp loose at the throttle body. If the system backfires the boot pops off the throttle body. We did this in the early days before pop valve where popular.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Porsche at the time was confident that the un-shielded wires were the air-box problem. I think it helped..but they still blow-up from time to time for no particular reason. |
Thinking about why you get a back fire in the intake is most likely because some spark plug is igniting while the intake valve is opened and fule air mixture is being ingested into the problem cylinder. So what can cause this?
1- Spark jumping from rotor to the wrong wire in the cap 2- Erroneous trigger signal seen from the points at the wrong time 3- Or simply the CDI deciding to fire with out a trigger Of these three possibilities I think #1 is most likely. These are CDI ignitions with plenty of voltage potential and I could see the possibility of having the rotor place it's arc to an adjacent post in the cap rather than the target post. #3 could maybe happen if battery voltage is significantly low enough? Just theory on my part.
Air/fuel mixtures at ambient pressure are most volatile and easily lit off. In contrast, within a cylinder as compression progresses and pressure increases the mixture becomes more stable and harder to ignite. Ignition is most difficult in the peak torque area of any engine as VE increases. I'm just pointing out that air/fuel mixture just sitting within the entire intake is extremely volatile and easily ignited by any flame or spark source.
scarcellar - Thanks for your comments. It's not likely I'll ever get a definitive answer that the low battery was the cause of the backfire, but the car has "only" 58k, has always been professionally serviced, and had never once backfired, stumbled, or failed to start.
Looking ahead to when I have everything back together, I will do my best to ensure I have not overlooked any potential causes of the original backfire. I will be replacing the rotor and cap (and spark plugs) as a precautionary measure. Hope to be back on the road in a few weeks. Spring has finally arrived here in Mass. hasn't it? |
Think of a pop off valve like a fuse in an electrical circuit. You are correct in the fact that if the system is tuned properly this will not happen, but that is an assumption over the long run. Put in a pop off valve, if you have a back fire, thank yourself that you installed a pop off valve, and use the money you saved in buying a new air box to tune your engine back to spec. You've already learned a hard lesson, why re-live it?
Proactively seek negative feed back. ![]() 1983 SC Targa |
A pop off valve is a must. Low cost good added insurance.
Just insure you install it properly. |
Then go to eBay and get a Webb Industries Stainless Steel beauty, I did and never worried again.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
From the recent posts I realized that I haven't said which direction I am pursuing.
![]() My replacment airbox has a pop-off and has been tested to ensure it is not leaking. I decided that the pop-off "might" be helpful if I make a terrible mis-step (being a newbie to CIS) but that potential benefit outweighed the responsibility of adding a new element to periodically inspect, maintain, and (let's hope not) troubleshoot. And back on topic, when I began prepping the engine for removal, I discovered the O2 sensor was disconnected. Doesn't seem like a likely culprit, but comments are appreciated.
'82 SC cabriolet |
