Black and Blue
Will this A/C compressor bolt right in?
I found the following rebuilt unit:
http://www.a-aironline.com/default.asp?ItemID=161 I think it will bolt right in my SC, is this correct?
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Kemo, you might be able to buy the same unit new for the same price at www.ackits.com
I just bought a sanden compressor from them two weeks ago. They were very helpful and fast. Eric
1975 911 Carrera BLK/BLK |
Will these bolt on to a 2.7L with york A/C? I need a new compressor and that is exacly what I've been looking for.
I have one of these guys in my dirty engine compartment...
76 911 S White with maroon interior. Last edited by JeffW; 06-11-2002 at 11:17 AM.. |
Yes the Sanden 507 was the update for the old york. It draws alot less power from the engine. I had the updated Sanden already in my car but the compressor had a small leak. Purschased a new Sanden 507 Compressor set up for the original R-12 that the system ran on. You may have to modify your old mounting plate. I purchased the new compressor from ackits.com for $251.53 (PART#34006MD).
If anybody is interested I will sell my old Sanden 507 for $75.00 w/out shipping. Only needs the seal replaced. However if you have the money I alway's recommend buying the new unit.
Black and Blue
212 bucks seems like a good deal to me...
Boy I wish I had A/C.
My 72 911T is black-on-black with a black interior...complete with black seats and black lamb's wool seat covers! It looks good but seems like it should be part of a new weight loss program. |
Black and Blue
mgoldleaf,
If I could do without A/C in TEXAS, I would! Unfortunately, its a necessity around here...
it doesn't look like that compressor will mount to what I have in my car. Can anyone confirm for sure or can I get a new mount from the dealer?
Thanks, Jeff
76 911 S White with maroon interior. |
Black and Blue
jeffw,
Thats what im curious about too, it seems that it will bolt in, longways, such that the clutch is in the correct position, i wonder if there will be room with the airbox cover.
Yes it fits perfect, I have a 1975 911. You could call AMA (ackits.com) and ask them about a mounting bracket. I believe Griffiths also sells a mounting bracket for the Sanden 507 that replaces the York compressor in a 911.
Ok.. that makes sense. I saw the bracket on griffith's website. Are they more expensive for the compressor? Do you know what they get for the bracket?
ackits.com was the cheapest I found for the compressor that I was looking for. You might also try VERTEX in Miami. They might sell you the bracket at a good price.
Senior Member
Kemo,
The NipponDenso compressor is also standard on many American cars. If you call Checkers or any good parts store and ask for a ND compressor for the following cars, the price may be lower and available in your area. Joe Nippon Denso 10 P 15C: 87 Mercury Lynx, 88-90 Merc Sable 3.8l or 82-87 Toy Celica
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Who sells a bracket for that one or does it mount the same as the sanden? My original plan was to use a nippon denso
Since you guys are on the topic of A/C. I was planning to have my A/C system rebuild. I was wondering what type on AC compressor I should use on my 1972 911s with weber carburator. The compressor was taken off by the previous owner. The hoses seem to be intact. Also, there is no condenser. Any suggestion and cost estimates would be appreciated.
John (Too hot in Texas!) |
Senior Member
John,
Go with a rotary compressor as the old York was a boat anchor. The Sanden is a good unit but nothing wrong with the Nippon Denso either. While you are at it, put in new hoses and such to make it last. Since the PO has taken the old compressor out, your dryer is also toast, and will have to be replaced. Joe (who just moved out of Dallas and is not missing the humidity one bit)
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB Last edited by Joeaksa; 06-11-2002 at 05:17 PM.. |
Guest
Posts: n/a
Kemo,
Try Zims out in Irving. I got the compressor and conversion bracket for about $250. Mark |
