What's a reasonable rim runout limit?
I just got a Starrett dial indicator and, since the rear of the 930 is on jack stands anyway, decided to try it out on my rear rims. I placed the gauge plunger out as far as i could on the rim near the tire
The RH rim varied from 0 to -.015 and then to +.005. So a total swing of .020.
The LH side was better; it went from zero to -.012 and back. So total of .012.
I intend to measure the fronts too, but I am interested in what the spec is.
I understand that I am measuring total "installed runout" (my words) and that the observed runout might not be all rim related.
What's the outside limit I should be looking for? When is it noticeable in a vibration or wobble?
Ken
1986 930 2016 R1200RS
Old 11-02-2012, 04:30 PM
Ttt
Old 11-04-2012, 12:26 PM
if you need a dial indicator to see the runout than its not a problem
Old 11-04-2012, 02:09 PM
According to the Technical Specifications book 78-81 930:
Max permissable radial runout for steel rims 1.25mm
Max permissable radial runout for alloy rims 1.0mm
Max permissable lateral runout for steel rims 1.25mm
Max permissable lateral runout for alloy rims 0.80mm
Max permissable radial and lateral runout for rim + tire 1.50mm
Great little books
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 11-04-2012, 03:35 PM
E Sully's Avatar
HUNTER Measuring the wheel's runout
Ed
1973.5 T
Old 11-04-2012, 03:47 PM
Thanks for the specs and the link. Looking for that Tech Specs printing now.
Cheers.
Old 11-04-2012, 04:00 PM
