OsoMoore's Avatar
Is this CV Bearing Ok?
My CV joint had a ripped boot, but only 17K on it. I took it apart, and here are the pictures.
911SC CV Joint Teardown
Is it in good enough shape to just get a new boot, regrease, and use as-is?
The only imperfections I found are some small deposits on the outer surface (1403 and 1404) and some small lines of what looks like minor rubbing on some of the ball bearings (visible in all the ball bearing pics).
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 06-05-2013, 05:55 AM
I would get the new boot, re-pack it with new grease and use it. Looks OK to me, it doesn't appear to have any pitting going on there.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html
Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things.
Old 06-05-2013, 06:25 AM
Almost Banned Once
sc_rufctr's Avatar
They look better than mine.
- Peter
Old 06-05-2013, 06:34 AM
Nine9six's Avatar
It looks and is almost brand new. Grease it up, slap it back together and get on down the road.
Usually if when you find a torn boot, and the joint still contains a good amount of grease; a quick inspection, new boot, new grease and you're good to go.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 06-05-2013, 06:36 AM
Recreational Mechanic
Nickshu's Avatar
Wow that CV looks great. I would guess it has been replaced before. With only 85K miles and good boots mine looked horrible and pitted to hell.
I agree, repack it, new boot, and drive it!!!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 06-05-2013, 06:53 AM
OsoMoore's Avatar
There were no gaskets, backing plates, or washers in use. I need to figure out if I need those as well, or just a new boot with integrated flange (Pelican Parts - Product Information: 923-332-037-00-M84.) I'm also not sure if I need new CV joint bolts. The ones I have now are hex, so I don't need a special 12-point driver for them, but I fear they may be too short if the new flange is thicker, or I need to add plates/washers.
Old 06-05-2013, 07:00 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Agree those CV pics look fine. Be sure to use a high quality grease. Economy grease is one of the biggest reasons why CV joints fail/wear out.
If you decide to use "moon" plates and serrated washers, you need to increase the length of your CV joint bolts. You can get them in bulk for a great price. I buy them from McMaster Carr in boxes of 25
McMaster-Carr
Kevin L
'86 Carrera "Larry"
Old 06-05-2013, 09:39 AM
look better than any I've seen, repack and probably good for 100k miles
Sold: 1989 3.2 coupe, 112k miles
Old 06-05-2013, 09:42 AM
OsoMoore's Avatar
Where does the full ring (looks like a large washer, not the retaining ring) fit when you reassemble the joint? It fell out as I was removing the balls, and I con't figure out where it goes.
Old 06-05-2013, 11:13 AM
pete3799's Avatar
Washer (cupped side towards the CV) goes on after the new boot is slide on and then the CV, followed by the snap ring.
Pete
79 911SC RoW
Old 06-05-2013, 05:48 PM
