When to replace a pressure plate...
(I'm doing a 3.2 conversion for my '72.) Is there any reasonable way to determine if your pressure plate is getting tired? My clutch was working fine, but the pressure plate has to be at least 15 yrs old. It is an aluminum one (which our host sells for $969), so if it's still servicable, I'd like to reuse it (with a new disc).
Thanks. Roger
'72 911 3.2 '18 Mustang Eco PP '17 Mustang GT Conv |
If you're in the midst of such an ambitious project, it's apparent that your level of automotive expertise is high enough to where you pretty much already intrinsically know the answer. I presume that you're desiring a 911 3.2 specific answer. Unfortunately I have none.
However on a general level, I'll offer up an opinion based upon my experiences with Detroit steel dating back some 45 years. R & R'ing a transmission and clutch was a relatively straightforward, half-hour duration task, as removal of the pressure plate could generally be accomplished via removing a tin inspection cover. For performance purposes, it was desirable to also remove the flywheel so as it could be resurfaced and balanced along with the new disk and the pressure plate you were either reconditioning or replacing if the springs were broken or severely fatigued. This might add another half-hour to the job, if that, not counting machine shop time. So, the question becomes centered around how much time and effort is spent on R & R'ing the transmission to access the respective parts coupled to your 3.2 once it's assembled and installed. Are you going to wish that you had gone w/new "while you were in there" ? That's your call. |
Fleabit peanut monkey
I believe the Sachs Power Clutch has some add'l clamping force. So, not discounting what donagain1 says one bit about rolling the dice, I would go for it once some data is collected from the driver of the aluminum clutch. If was tracked or wailed upon then your risk increases. Here is some add'l data: How to check the pressure plate to see if it's still okay?
1981 911SC Targa Last edited by Bob Kontak; 10-17-2012 at 01:15 PM.. |
It looks great. I'll probably re-use it. Thanks. Roger
All the best.
1981 911SC Targa |
