Paint Update
I was actually able to shot some surfacing primer last night before I went to bed. This reveals all kinds of surprises! Oye! Ya gotta be careful letting your helpers use a DA, particularly on edges; there's going to be a lot of hand-sanding tonight!
I also detailed the areas around the cab top mounts, welded in all of the trim screw holes from the Targa trim, and fabbed the trim retaining strip for the top. Tonight I'll block out the surfacing primer, fix the little "discoveries" from last night, and then shoot another coat of surfacer. Friday night I'll block that coat of primer... http://vintagebus.com/howto/paint/
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Guest
Posts: n/a
Thom,
What are you going to use to control dust when you shoot the paint? I'm about to shoot my ducktail in the garage and haven't got the dust thing figured out yet. Thanks, Mark |
For the primer, I'm not being very AR about dust,but here's what I do when I paint:
Guest
Posts: n/a
Thanks man.
What are you using for fans to exhaust the fumes when you are painting? Or is the paint you are using not solvent based so you don't need to worry about explosive vapors?
Robert Currently Porsche less (but the wife has 2) |
Wetting the floor, in concept, sounded like a good idea, but in practice was not and I stopped doing it. When you wet the floor, everything gets wet, the airhose for the spraygun, etc. Its easy to splash water on the car while you are painting, obviously a bad thing, when you have the floor wet and water everywhere. I'd recommend just washing down the floor before you start, and letting it dry. I found that even in the garage, dust is not really a problem. The biggest problem I found was keeping the supply air dry and clean - compressing air creates a lot of moisture, and that can be disasterous to the paint. You are going to get a little dust and imperfections in the paint when you paint in your garage. They KEY, though, is to put enough paint on the car so that you can do a pretty aggressive color sand. That will take care of any dust, imperfections, etc. There is a danger of putting too much paint on, but for a garage job, its better to have a little too much than a little too little. You can and will be color sanding and doing a lot of polishing - you need to have enough material on the car to handle that. |
Senior Member
Thom:
Could you explain the pics and what you said about revealing problems? That is, do these pics show a post-sand that has revealed the low and high spots? I think I see what looks to be a car that has been block (or at least flat-backed) sanded and thus we are looking at the low and high spots. Can you confirm? Nice work BTW. I would love to do what you are doing. John
'78 Targa in Minerva Blue |
Why is the windshield still in?
Guest
Posts: n/a
Thom,
Why not set up a web-paint-cam in your garage so we can peek in on you progress (and count beers in case you forget)? Mark |
Thom,
Are you using PPG's DPLF Expoxy Primer? I noticed you are using the single stage CLV was just wondering what you are putting underneath. I don't know how you do it. I am just trying to repaint my rear valance and I only have the primer/surfacer laid down. The way you are going, your whole car will be done before my one panel! Keep up the updates Pete |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Some Answers...
Free labor is great. What is color sanding?
-kb- |
great job
would you like to paint my 1970 911T also?
im looking 4 someone to paint my car too |
Looks like its going to come out great!
I've found painting a lot of work, but also a lot of fun and probably the most rewarding auto project around. Can't wait to see your results! |
Color sanding is using very high grit paper (ie 2500) with water to block out orange peel, dust, fisheyes or other imperfections - basically sanding the final paint to make it perfectly flat. Then that's followed up with a buffer and polishing compound, and then a machine glaze.
