Failing headlamp switch?
My headlight switch sometimes needs a tap on the pull out or a turn on the rheostat to get the dash lights to come on.
Failure notice on the switch or a loose connector? They are a PITA to get to and to test.....anyone BTDT. |
Headlight Switch.
In my opinion, pull the switch, clean the wiper. No joy, replacement time....... Good luck, Gerry |
got relays?
this often seems to indicate incipient failure, but could just be dirt & crud in there -- hose it out with elec. contact cleaner and see if that fixes it |
Yep....relay kits for both the H4s AND the driving lights. Looks like I'll drag out the Bentley and start a diagnosis....:rolleyes:
Hey M,
I attempted to rebuild mine but ended up replacing it, the rheostate just worn out. If you do get a new one re-check the mechanism, for some reason the quality is not the same from PAG and I had it replaced. It should be a smooth but snug movement. J |
| All times are GMT -8. The time now is 09:23 PM. |
