RETIRED
Failing headlamp switch?
My headlight switch sometimes needs a tap on the pull out or a turn on the rheostat to get the dash lights to come on.
Failure notice on the switch or a loose connector? They are a PITA to get to and to test.....anyone BTDT.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Headlight Switch.
In my opinion, pull the switch, clean the wiper. No joy, replacement time....... Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
AutoBahned
got relays?
this often seems to indicate incipient failure, but could just be dirt & crud in there -- hose it out with elec. contact cleaner and see if that fixes it |
RETIRED
Yep....relay kits for both the H4s AND the driving lights. Looks like I'll drag out the Bentley and start a diagnosis....
Member 911 Anonymous
Hey M,
I attempted to rebuild mine but ended up replacing it, the rheostate just worn out. If you do get a new one re-check the mechanism, for some reason the quality is not the same from PAG and I had it replaced. It should be a smooth but snug movement. J
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
