white rabbit
Pressure bleeder on 911 hydraulic brakes & clutch procedures
Hi all,
I have Had my 1988 911 Carrera for about 4 months and am gradually repairing and servicing the needed items. After reading PP Tech. Info for a while I am going to flush my hydraulic systems in the brakes and clutch. I am going to use my tried and true "Motive Brand" pump up pressure bleeder at about 6 to 8 # pressure. My question is, I have always used it on systems that had the brakes and the clutch hydraulics on entirely seperate systems. My 1988 Carrera seems to have both systems operating off of the same master cylinder. A. is this correct? B. How do I block off either system side to keep the pressure out of the system not being actively bled at the time? C. Is there some hose/line that needs to be crimped/clamped off to prevent this. Or am I completely misinterpreting this perceived necessity. Thanks ahead of time for the assistance, Don |
Member 911 Anonymous
As I recall, there is a hose that is crimped to segregate the two systems at the reservoir per Bentley manual.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Flat Six
IIRC, G50s use a common reservoir for brakes and clutch. General procedure is:
-- Pinch/compress overflow hose -- Fill & attach pressure bleeder (fill w/new fluid from never-previously-opened container) -- Pressurize & bleed RR / LR / RF / LF (for LHD cars) -- Keep Motive bleeder filled w/fresh fluid -- Attach hose from bleeder nipple (on clutch slave cylinder) to open glass container -- Open clutch slave cylinder bleeder nipple until new, fresh fluid collects in glass container and no bubbles remain -- Depress clutch pedal several times -- Close clutch slave cylinder bleeder nipple -- Enjoy cold beer HTH
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport Last edited by Flat Six; 10-23-2012 at 11:30 AM.. |
white rabbit
Thanks Draco and flat six for the info. I have the Bentley Book on the way from our hosts. So will put this off for a week or so.
Don |
