fbeatty's Avatar
Always on the last things to do
So I have posted a few time about dropping my engine to do the clutch.
I thought the CV shaft bolts were tough... They don't compare for $hit to the oil lines. The joint right back by the tank drain plug is driving me nuts. The only things left to do are the slave cylinder and the oil line until I can drop the engine...
I have big adjustable wrenches, but the damn thing wont budge. Not to mention, as always I am freaked out about putting so much force into it...
Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium and Strontium 90)
08 Cayman, 88 911 Targa, 93 MR2 Turbo, 2012 Jeep JK
Old 10-20-2012, 12:53 PM
RETIRED
Joe Bob's Avatar
Heat....Mapp gas.
2012 ML350 3.0 Turbo Diesel
Old 10-20-2012, 01:06 PM
Project Addicted
Mapp gas is the one in the yellow bottle at the hardawre store. It will fit your standard propane torch that you mighht have laying around which has a blue bottle on it. Burns significantly hotter than propane and will usually help loosen siezed up bolts and fittings. Try to heat only the outer most siezed up part so that it is on only thing "growing" bigger and therefore getting looser.
Good LUCK!!!
Old 10-20-2012, 01:23 PM
AutoBahned
RWebb's Avatar
drop the whole thing as a unit and deal with on the bench
Old 10-20-2012, 03:03 PM
fbeatty's Avatar
Thumbs up
Woohooo!!!!!
It came loose. Thanks to scotricker, thank you, thank you, thank you...
His message, suggestion and post
Joined the Engine Drop Club! Required Photo Included
worked like a charm. No heat, no damaged nuts and no sacrificed line.
Thank you to all who had suggestions.
Scotricker, I will talk with you later with a delivery.
Old 10-21-2012, 01:47 PM
