-   -   911 engine number confusion help (http://forums.pelicanparts.com/porsche-911-technical-forum/712693-911-engine-number-confusion-help.html)
makoto 10-22-2012 09:47 AM
I'm new to this forum and Porsche in general. I have a Laser 917 kitcar that was built with a Porsche transmission and a 6 cylinder Porsche engine. I've researched the engine and can;t seem to find exactly what I have. The only info I have currently is the number 911.105 111OR That number is on the cover over the valves. On the engine block below the fan, I found the number 3280491. I hope that one of these is the engine number. I'd sure like to know more about this engine. I was told that it is a 2.0liter engine. Any help is appreciated
makoto
Matt Monson 10-22-2012 10:05 AM
That 2nd number is the engine number. 1968 normal engine. Should be a type number (5 digits) near it on the case.
makoto 10-22-2012 10:07 AM
I'll have to keep looking. There is no room to access things or see well. Thanks!
makoto
Matt Monson 10-22-2012 10:42 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/121529-911-engine-codes.html
Post #7 shows you where to look. It's just past the serial number a little bit.
djpateman 10-22-2012 11:28 AM
3280491 is the serial for a type 901/14 aluminum case 1968 911 normal engine. Should be about 130 hp. I think this thread will help more:
http://forums.pelicanparts.com/porsche-911-technical-forum/100507-third-number-engine-case-2.html
The build # will be in the 114xx range I expect; please let us know.
