Recreational Mechanic
Fuel tank to Fuel Pump line - What to order??
I need to replace this short flexible line circled in red on the screenshot below. The factory service manual says only "90mm" for this line and does not list a part number. Can someone point me to the correct fuel line that I can order from Pelican? I assume in bulk/by the foot. Thanks!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Member 911 Anonymous
You can get that at any flaps just cut to size.
I think it was 3/8" dia.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
So that would be 9.5mm metric equivalent? I think our host sells 7.5mm and 11.5mm.
I'll check with my FLAPS, but I don't think that they carry metric. I guess I'm being too anal, I should just use 3/8"
Senior Member
Great question - is there any consideration for Ethanol-resistant line here? That is, could we over-spec. the material here for both strength and resistance to the corrosive elements in our fuel?
Or will a standard rubber fuel hose just last another 20 years anyways?
'78 Targa in Minerva Blue |
![]() It is 11.5mm, available from our host. Len
The only reason I changed it to a fuel line hose was after my PPI, Tony Callas, Callas Rensport in Torrance found it to be cracking, Not yet leaking though.
AutoBahned
yes, use EtOH rated hose- Goodyear makes one
J30R9 is an SAE spec. for the above but part of it is for FI pressure rating - not sure which part |
