non-whiner
Widebody stress wheel bearings?
So, I'm converting my 1984 911 to a widebody. My 930 uses special wheel bearings (read as expensive). I'll have to purchase new wheels and I'm wondering if the offset required puts extra strain on the standard wheel bearings? Is this an issue?
"Too much is just enough." |
most people here will say yes. I say hell with it and worry about it when they go bad. Personally i dont think it makes much of a difference. Think of it this way. On a tire centered on the bearings its pushing up equally on both bearings. When its offset the outside is pushing up and the inside is pushing down. they still have the same load. I dunno maybe the outer gets more weight on it but if they cant stand up to a little more weight they were probrobly going bad anyway. My car was converted back in the 80s and as far as i know the bearings are still original
82 SC , 72 914 |
The solution is to have wheels made with the correct offsets/backspacing for your car to minimize bearing stresses.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
For a wheel of a given width that puts the tire at a given distance from the wheel bearing (filling out the flare) it seems to me the bearing would see the same loads no matter if the wheel offset puts the tire in that place or a combination of wheel spacer and wheel. Am i missing something? To the original poster: The further you put the tire away from the wheel bearing, the more stress it will see. It has more leverage. |
just me
how much more expensive is it to do it right than to do it over and over again incorrectly?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Racer
Basically, when you add a spacer you are increasing the length of the lever and that puts more stress on the wheel bearing. The lever length is not increased when you change wheel offset to get the same track width.
The distance from the face of the wheel mounting pad to the bearing is the lever length. Add a spacer and it gets longer. Change offset and it does not. Scott Last edited by winders; 10-29-2012 at 05:02 PM.. |
non-whiner
Scott, are you sure about that? It seems to me that the further the outer edge of the tire is from the bearing, the more stress. Shouldn't matter if its a spacer or offset.
Am I missing something?
non-whiner
I guess the follow up question is are the banana arms different between the narrow body (911) and widebody (930)?
Racer
Scott |
Racer
I'm running pretty wide wheels on my car with a widebody and I haven't run into wheel bearing issues. All of my cars have been built with really low offsets and much wider track widths than stock. I've only replaced rear wheel bearings on my 911 because the po didn't torque the hub nuts and they backed off. Other than that I've had 0 wheel bearing issues.
Does it add more stress? Yes Does it cause bearings to fail? Not in my experience, or from what I've seen on any of my friends/track buddies cars. Lots of us on here are doing it either with offset or spacers. I'm sure you'll get some good feedback.
that911.tumblr.com |
i also have wide wheels 12 inch wide in the rear running 335 30 18. for the past 5yrs still no issues 275 35 18 in the front
1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver |
non-whiner
That's what a wanted to hear!
Did you add the flares to a stock 911? |
Member 911 Anonymous
+1 what Scott said, at least in my situation. I placed 1/4" spacer on my passenger rear to compensate for body defect.
I developed a clunking noise at the bearing and recently replaced both, driver side was still good but replaced both in pairs. J
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 10-29-2012 at 07:14 PM.. |
![]() yes i have 13inch flares in the rear 11inch in the front
non-whiner
Wow, that tangerine is a real beauty!
2 sets of bearings and labour to remove old and fit new is probably less than $1000 all up.
Having to replace them once every 10 years with widebody and offset rims instead of every 20 years for the narrow body and standard rims kinda puts it in perspective. I't not a big issue. My SC with widebody guards and wider wheels using spacers for the offset is 30 years old and the current rear bearings are 7 years old and not showing any issues. Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. |
I dont use spacers.
Oh thats not tangerine
