Giovanni86, I do have a friend looking to get rid of his 2.4, which I could bump up to a 2.7.. This is also an option, but again, there is no substitute for displacement...
I would not use a 3,2 because when you look at your engine you will like to see old stuff:
compare this: http://farm4.static.flickr.com/3351/...9ccabd0131.jpg to this http://grassrootsmotorsports.com/med..._3.2_liter.jpg |
I have to say if you want "old feel" I'd strongly consider a 2.7. It'll look the part, rev well and easily get 200hp with cook book formulas from several good builders.
If you want to make easy 200hp for possibly less money, then why not pick up a 3.0 at a cheaper entry point especially with Euro P&C's or some JE's in there to get it nearer 10:1 under PMO's. It won't be "accurate" but will mostly look and sound the part with 50% more cc's than that 2.0 for better street manners and durability. Selling a good 2.0 will get you a ways into a 3.0. 3.2 EFI will be quicker likely in street trim, but won't sound or rev the same. Certainly as mentioned above, doesn't look as good. Not sayin a 3.2 isn't great, but if your weighing options of retro vs displacement why not shoot in middle and get a little of both? |
No matter the engine size I am still planning on PMO carbs, so I will get the retro look either way. What do you think I could get for my 2.0 911E w/ zeniths and Carrera chain tensioners?
Need more info on the 2.0. If an original E, it could help re establish some value to an otherwise restored 911E with say a T or L engine. To that individual it could have real value......considering you can get a 3.0 for $4k, might get in the even territory I would think if in 'like' condition and complete with reasonably sound numbers.
I'm just having fun. I love the smaller displacement motors with carbs & MFI. But after 14 years of that, I'm ready for a change. There's no wrong answer here. Do what makes you happy! Roger |
Roger |
A fellow local PCA member is giving me a deal on a 2.4 that I can't pass up. I'm going with the 2.4 with the possibility of bumping it up to a 2.7 complete with PMO carbs and headers. The 2.4/2.7 is more of a period engine, and I think the low end of the 3.2 is enough to get me in trouble.
Why yes you can
And you don't have to break the bank. It's just about the right parts. This uses stock port, small valve heads (no need for the spendy 69S).
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/566662-2-0-engine-excellent-performance.html Question is would you rather be having a screaming ball at 55 or 105. One of the things I really liked about my RZ350. It was a blast at 65. Much easier on the license! t |
3.2's can look retro...
http://forums.pelicanparts.com/uploa...1351763958.jpg In my '69 you can't tell it's not a 2ltr, until you start it :) |
So I pulled the trigger on a 2.4T. The deal was too good to pass up. The plan is a variation of the 2.4 with 2.2S pistons.
The top end came mostly disassembled, and without fuel injection. It was an MFI motor, so I bought some cheap Zeniths, a couple carb rebuild kits, and some 2.2T heads so I don't have to deal with plugging the hole in the 2.4 MFI heads. For my Zeniths I am looking at buying main jets from I am planning on buying some custom JE pistons. I am now debating whether to order 9.5:1 pistons and stick with single plug, or jump the compression to 9.8:1 or ~10.2:1 and twin plug. I need to send my heads off to get built anyways, why not get them ported, then drilled and tapped for twin sparks at the same time? I have an MSD unit, and heard you can run twin plugs off of one MSD. What do you guys think? http://forums.pelicanparts.com/uploa...1365648384.jpg Old bits http://forums.pelicanparts.com/uploa...1365648442.jpg http://forums.pelicanparts.com/uploa...1365648498.jpg New bits http://forums.pelicanparts.com/uploa...1365648544.jpg tl;dr Have: - 2.4T core - Zeniths - Solex cams Need: - high compression pistons - 34mm venturis - Larger main jets (160ish?) Question: - Twin plug while i'm in there? |
"and some 2.2T heads so I don't have to deal with plugging the hole in the 2.4 MFI heads"
They sell little plugs that are made for this. I used them when I switched to Webers on my 2.4T MFI. I don't recall if 2.2s and 2.4s used the same valve and port sizes. If the 2.2s are smaller, then I would definitely get a set of the plugs and use the 2.4s. Otherwise, it probably comes down to condition of the heads. Enjoy! Roger |
2.4T ports I remember being smaller than 2.2T ports for some reason , 2.2T and E ports are same size. I'm pretty sure port sizes are the only thing that changed with 2.2-2.7, but I'll have to check my engine rebuilding book when I get home. My 2.4 heads are newly re-built, but I think I want to port the heads to S size, (and contemplating twin plug), so I bought core 2.2 heads instead of messing about with the newly rebuilt 2.4 heads. If anyone wants brand new rebuild 2.4T heads, I'll sell them to you.
With 85mm pistons and increased compression to 9.5:1, or 10ish:1, I would like to be on the safe side and not have to worry all the time about fuel quality. Hence twin plug. (Plus it looks cool!) My dream is 85mm JE pistons, 10ish:1 compression, twin plug, solex cams, S spec heads, and 34mm venturies with my zeniths. I may have to settle with 9.5:1 compression and single plug, but I really want to twin plug. My piston choice depends on whether I twin plug or not. Anyone have experience twin plugging with 1 MSD? |
I think you're right on the ports. If memory serves me correct, when I measured the ports on my engine, they were only 29mm. This was actually smaller than the figures given in some reference material.
I had similar aspirations for my 2.4 motor, S cams, S ports, JE 85mm 9.5 (I was planning to simply bore the iron cylinders). I think that should comfortably give you the 200 hp you were looking for. I assume you are rebuilding this yourself? Either way, get ready for a whole lot of "while your in there" expenditures! Roger |
Nice to see this thread come back.
Twin plugging is neat, but add several thousand to the price of the build. Is it worth it to you for 20-25 more HP? |
Roger |
The problem with Porsche ownership. $40k for 200hp...baawwahahahahaaaaaa 3.2SmileWavy |
(my net cost for 215 hp will be around $3K...3.2 :D) |
| All times are GMT -8. The time now is 10:25 PM. |
