Spark Plug Blew Out of Hole
First, I know, minimal P-Car content but you guys are SO helpful.
My 1970 VW (you know the car that traces it's ancestry to Dr Porsche) Bus (an early Cayenne) had the #1 plug blow out of it's hole. There was no foreign material on the plug threads. When I performed my road side fix, it went in about a turn or so and got very tight. I reinstalled the wires lead and started it up and drove home. I was able to get home without it blowing out again. I know the "best" way to address this issue is to intall a Timecert. I am thinking that since there was no head material on the plug, it may have worked it's way loose and the difficulty in threading it in may be due to carbon buildup instead of galled/damaged threads. Does it make sense to try brushing the thread with a wire brush and using thread chaser to clean them up instead of immediately jumping to a timesert?
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-27-2012 at 06:46 PM.. |
Senior Advisor
sure does harry, try the least invasive fix first. i think there was a thread (no pun) on here about that same thing. it just unscrewed itself from the cylinder (going from positive to negative pressure).
08 Cayenne Turbo |
ASE Master Tech - 35 yrs
just get the re-threadtool & insert kit - multiple sources on eBay etc
prices all over the maop - so shop carefully - they are all the same I get mine at Bugformance
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Harry...you had my imagination on redline with that one!
What hole? Etc, etc. :-)
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Project Addicted
As the plug probably unscrewed, it blew out when engaged with the first thread or two and caused some damage there. Chasing the thread is probably best and least invasive. You can coat the chaser with grease to keep any metal bits from dropping into the cylinder.
Good luck! |
Just lost #1 plug. Turns out, if you try to put the plug in a hot engine, the expansion of the aluminium head is such that the plug cannot go in very far. This morning with a cold engine, it took out the plug (barely hanging in) and put some copper antiseize on the threads and threaded it in by hand. Went in with no drama, tightened it up and took a brief drive. No drama not problem.
And now .. the last thread gave up the ghost and the plug popped out.
Sigh ... time for a timesert.
Good luck with the repair. My twin brother and I both had brand new 70 VW's. His blew a plug out at about 40k, no reason known or given ( fix was a timesert or whatever it was called back then) and my VW ran great until I sold it and got a 356. It was kind of a known problem back then. Good luck Steve
Steve 1970 911T SOLD 1989 3.2 Carrera 2013 991 Carrera S |
SWMBO
Had the same problem with our 70 VW bug, had to put in an insert and a few thousand miles later, had another problem:
![]() I think that the problem with the plug and misfire, had bent the exhaust valve stem and eventually it crapped out into the cylinder; fixed now, upgraded type three motor , and rhino gearbox, goes like the clappers now,
1985 911 Carrera Cabriolet GPW - Marilyn1972 911T GPW- Pusha (IT LIVES) ![]() 1961 356B Heron Grey -Miss Daisy (currently in restoration) ![]() 2000 HSV GPW (goes fast,everytime!) ![]() 2003 Indian - Spirit
