Is it possible to flush mount 6 x 9 speakers in a 1988 911.
I have the chance to acquire some NOS Jensen J3033 that have the nice flush speaker grill. Will the speakers have enough room for mounting under the cutout in the parcel shelf ..... |
Go-Kart Mozart
I think you'll find there is not enough depth to mount those speakers. Can't be more than a couple inches to work with. -J
I have 6 X 9's in the rear deck installed by I a PO and they stick up a few inches.
Do you have the original 4 X 6 with the original grilles? I want to go back to original but cannot find the grilles. Where are you located? Bud Gamage 1987 Carrera Coupe Guards Red/Black interior. |
Some other thoughts:
Finally! 911 3.2 rear speaker replacement without any modification I used Blaupunkt THx 462 and the grills look pretty stock. They fit the stock hole, 6x4. I don't think a 6x9 can fit without being proud of the deck.
1988 Carrera Coupe |
I have found some great substitutes for the NLA '87 speaker grills Have them in my car, a perfect fit and they look great. Sent you a PM with info.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Kenwood makes an unobtrusive, drop-in replacement. Ordered mine from Rod at Car audio innovations. Something like $100 shipped.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
El Duderino
In my opinion, the rear deck speakers don't add a lot to sound quality because they fire into the rear glass and reflect. I know this because I'm stubborn and had to learn this lesson myself even though I got the same advice. Live and learn. I wouldn't worry to much about spending more $$$ than just a set of "good" speakers, unless you're getting a good deal. The larger speakers will be hard to fit though because there is very little depth. Some people have made spacers to get a little more depth and accommodate the larger speakers. That's a judgment call. I've seen some that look ok and some not so much.
FWIW, I decided to remove the rear shelf and do away with the rear speakers. Repaced with RS carpets when I redid the interior. I put 7.1" Hybrid Audio Technologies mids in the doors and mounted a set of tweeters in the aftermarket under dash panel.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
I installed 5x7 in my Targa in the original location as the 4x6, the back deck was high enough and the speakers were low enough (about 2 1/4 inch high) which fitted perfectly. I gain a lot more bass and when combining the doors speakers it sounds really good. I think 6x9 would be cool if you can find a set that are really shallow or at least 2 1/8 inch in height. Also you can check for Retrosound speakers which make a really shallow 6x9's the depth mount is only 1 13/16 inch. If not check for spacers and top mount them but they may not look to good.
x2. well said. think of it like a concert - how many speakers are playing behind you as you listen?
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
None. But depending where you watch the concert, the auditorium is as close to acoustically perfect as can be. The interior of a Porsche? Not so much. Just sayin...
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot.... |
I too will be looking for new speakers soon as I have a new interior coming with original rear shelf unmolested. The Retrosound speakers look as if they will do the job nicely just hope I dont have to butcher the shelf to make them fit as it has the grille incorporated into it.
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
compare the size of a 911 interior to that of a concert hall... front speakers are more than enough hell they are more than enough for just about anything on the road.
I used to think that the rear speakers didn't do much. I bought a decent Pioneer head unit, had Rod at Car innovations (terrific guy) install pricey component Hertz speakers up front and Blaupunkt stock looking in the back. No amp.
Four years later the front speakers are toast and rears are still going. Not great but I can still jam to Larry Coryell with the sunroof open on the freeway. I think the rears do add something to a challenging acoustic environment. I am glad I didn't ax them like I was thinking. Seems to fill in the sound when all 4 (or 6 if you have a later Carrera) are working.
I have Sony 6x9's in a custom back deck. They're very loud using just the power provided by my new Pioneer head unit. I have matching door speakers w/ separate tweeters but they're smaller so I fade it to the rear slightly because the 6x9's can handle more bass. The sound does bounce off the back glass some, but when I turn it up really loud it's not noticeable. Sorry but I do not know where the custom deck came from, the PO installed it. Looks simple though.
El Duderino
El Duderino
There just aren't a lot of great options in the stock opening. I think depth is the biggest issue. |
El Duderino
I still have the Blau's by the way. PM me if you're interested.
