Danimal16's Avatar
Correct Ball Joint Help
I am installing a set of the 3.5 inch spaced Boge struts to replace the original early 3 inch spaced Boges. Which Ball Joint do I use?
Thanks in advance for the help.
SIncerely,
Dan B
Dan
Old 10-28-2012, 01:43 PM
Danimal16's Avatar
anyone??
Dan
Old 10-28-2012, 03:13 PM
Shaun @ Tru6's Avatar
Hi Dan,
Ball joints are all the same 69-89 for all single pin type struts, as you have. I think the threaded bolt type struts have a different ball joint. below will work just fine, good luck!
Porsche 911 & Carrera Suspension - Page 14
Tru6 Restoration & Design
Old 10-28-2012, 03:35 PM
Danimal16's Avatar
Originally Posted by Shaun 84 Targa View Post
Hi Dan,
Shaun,
Thanks.
Are you back at 100% yet??
Dan
Old 10-28-2012, 05:10 PM
Still at 90 Dan, but with enough Advil, I can still have fun. I think in January I'll be back to normal.
Old 10-28-2012, 05:32 PM
