jazel's Avatar
Question Replacement dash top speaker for '71
Has anyone found a 4" x 9" speaker to put in the dash top on the older models? I can't come up with one doing a search. I'll probably just adapt a 4" x 6" 2-way if I can't find one.
Jack Zelms
jazel@sitestar.net
'71 911T coupe
Old 06-17-2002, 09:43 AM
one of gods prototypes
bell's Avatar
the size is actually conbsidered 4x10.
the problem with the single speaker is all radios newer than 1980 roughly are stereo only so you'll not be able to get the full recorded sugnal if you have a newer radio.
a common replacement which i do frequently is to make a 4x10 plate with holes cut for either two 4" speakers or two 3.5" speakers. this will let you get the "stereo" signal (with both speakers in the center though you won't get a stereo image) .
you will loose a little of the bass response by doing this since they are smaller speakers but the mid-high quality will be much better.
hope this helps
Brought to you by Carl's Jr.
Old 06-17-2002, 06:30 PM
