-   -   First Engine Drop (http://forums.pelicanparts.com/porsche-911-technical-forum/714260-first-engine-drop.html)
zippy_gg 10-31-2012 02:41 PM
First Engine Drop
Must be the season as I see a few threads on engine drops this week.
Anyway here are my questions:
All instructions say to disconnect the fuel lines. I found and disconnected them from the fuel filter (no accumulator on my 86). What other fuel lines do I need to disconnect before the engine drop?
Do I also need to disconnect hose #34?
http://forums.pelicanparts.com/uploa...1351719682.jpg
Thank you Gerry for the picture.;)
kodioneill 10-31-2012 02:51 PM
Do a partial engine drop and you'll see what needs to be disconnected.
zippy_gg 10-31-2012 04:29 PM
Hmm... I expected more detailed from those with same model/year car.
I will be doing this drop solo with a jack so I'll have to be careful about balancing the engine while slowly lowering it (instead of dropping :D).
sjf911 10-31-2012 04:40 PM
There are only 2 fuel hoses that need to be disconnected. The first is the high pressure supply line that exits the fuel filter and the second is the low pressure return line that hooks up at 11a. 34 does not need to be disconnected unless you are going to remove the MAF and intake elbow before engine drop.
audi 10-31-2012 05:54 PM
I did mine solo as well; a little off-topic but I found it less nerve-wracking to lift the car off the motor than drop the motor from the car. I used 3 jacks (had 2, borrowed one), one on each side's jack pad, and a third to help keep the nose of the transmission centered in the tunnel until the rear was high enough to pull the motor straight back and out.
If your motor's up in the air balanced on one jack and it gets wobbly, and you're by yourself, there's little to do but get out of the way...
However you do it, go slow and keep an eye out for anything still connected or that got hung up as you separate the car and motor. Anything you missed or forgot to disconnect will be pretty obvious.
Good luck!
fbeatty 10-31-2012 07:05 PM
zippy_gg, sjf911 is correct. There are only the 2 fuel lines to disconnect. The others you have marked can stay connected.
Just go slow with the jack. Make a platform to give it more width if you can and it will stabilize things out.
boyt911sc 10-31-2012 07:06 PM
Recent emgine drop........
Four weeks ago, I dropped the engine of '87 Carrera to inspect the clutch disc and disconnected the following:
Delivery fuel line
Return line
Brake booster vacuum hose
Disconnected 3 electrical plugs left side of engine and 4 on top of the egine
Ground wires left side
14-pin connector
Ignition coil cable
Hose behind air box
2 hoses from throttle body going to the right side of engine bay
Square connector behind engine (center left)
CV joint
S-hose
Oil line to aux. thermostat
A/C
transmission linkage (tunnel)
clutch cable
starter cable
transmission ground strap
accelerator linkage
speedometer wire from sensor
sway bar
engine breather hoses
disconnect batter cable
And a few things that I forgot........
Tony
zippy_gg 10-31-2012 07:51 PM
For clarity sake, the items in purple are the lines to be replaced once the engine is out of the car. I borrowed a picture posted by Gerry to try and identify the fuel lines I need to disconnect for the drop.
I tried disconnecting 11a but that little bugger is really tight...:eek:
Is the brake booster line represented in the diagram? I thought it was 34 but was corrected earlier.
DRACO A5OG 10-31-2012 07:55 PM
Just at fuel filter ;-)
I'm in the valley allot. Pm me if you need a hand or moral support.
Jim
zippy_gg 10-31-2012 08:53 PM
Jim
I understand all that comes at a price.... Good thing I keep Stella in my fridge! Let's chat!;)
fbeatty 10-31-2012 09:07 PM
Draco has offered me suggestion in the past that have helped. Good to see you have him close by for support.
zippy_gg 11-03-2012 07:40 PM
Thanks to Jim (Draco) who came by this morning my engine is now on the floor.
http://forums.pelicanparts.com/uploa...1351996733.jpg
After separating the tranny from the motor we checked the clutch and found it was worn down to the rivets on the flywheel side. Time for new Sachs parts!
http://forums.pelicanparts.com/uploa...1351996502.jpg
The original Boge rear shocks were toast.
http://forums.pelicanparts.com/uploa...1351996587.jpg
Next the banana arms come off for new polybronze bushings...
Oh yeah... I am just Jim will post the mandatory "jack in the box" picture he took of me in the engine bay...:D
DRACO A5OG 11-03-2012 07:51 PM
Mais Bien Sur,
http://img.photobucket.com/albums/v5...103_123252.jpg
http://img.photobucket.com/albums/v5...103_123311.jpg
fbeatty 11-03-2012 08:09 PM
Congrats zippy_gg, let us know when you get it back together.
zippy_gg 11-03-2012 08:16 PM
You bet Fbeatty! But it may take a while as I am replacing all suspensions and brake components, and some electrical work.
I'll update this thread as I make progress.
fbeatty 11-03-2012 08:42 PM
Cool, keep in touch. I have to get the bell housing on my transmission fixed so I am in the same boat. It is going to be a while
flatsixjunky 11-04-2012 03:17 AM
Bien joué zippy
Take care
pensacola mike 11-04-2012 04:52 PM
Looking great! Keep us informed and lots of us pictures too
zippy_gg 11-04-2012 08:47 PM
Removing the rear wheel bearings is a real joy...
Driver side
http://forums.pelicanparts.com/uploa...1352090762.jpg
Passenger side
http://forums.pelicanparts.com/uploa...1352090793.jpg
2porscheguy 11-08-2012 03:12 PM
Subscribed!
Gilles, je vais te joindre bientot. Je suis dans le meme bateau!
I'm planning my first engine drop sometime this winter, so please keep us posted Zippy!
Alex
zippy_gg 11-08-2012 03:34 PM
Originally Posted by 2porscheguy (Post 7080424)
Subscribed!
Alex
Alex, ne coulons pas le bateau! :D
I started another thread for the work I am doing on suspensions/brakes, then I'll come back to this thread and update.
zippy_gg 12-07-2012 08:42 PM
Flywheel out (I used a spring plate as the "special" tool to lock the flywheel while removing the nine 12 point bolts ;))
http://forums.pelicanparts.com/uploa...1354941541.jpg
http://forums.pelicanparts.com/uploa...1354941623.jpg
http://forums.pelicanparts.com/uploa...1354941686.jpg
I took my flywheel to the local machine shop and the guy just freaked out once he recognized the Porsche part and said he could not do it.:confused:
Anyone knows of a local shop that would do this?
zippy_gg 12-08-2012 06:01 PM
Guess who?
You'll never guess who could resurface my flywheel...
Motor Meister - Porsche Engine Rebuilder
Like it's going to happen! :D
JJ 911SC 12-08-2012 07:06 PM
Could not find a "Testimonial" link on their website :rolleyes::rolleyes::rolleyes:
Gilles
Comment vas "the while your are in there"???
zippy_gg 12-08-2012 07:19 PM
Gilles
Well JJ... let's say that the While you're in there is ever expanding...! :D
zippy_gg 12-22-2012 12:37 PM
As part of my vert slowly moving project I am replacing the clutch cable, following this tech article Pelican Technical Article: Clutch Cable Replacement - 911 (1965-86) - 930 Turbo (1975-86).
I have released the cable at the clevis and now trying to pull from the engine side.
The cable seems to resist my pulling and tugging and I am wondering if I just need to use more force or if I am missing a retaining clip...
This is where I am at (pic from the tech article).
http://forums.pelicanparts.com/uploa...1356208503.jpg
Do I just grab the cable with pliers and pull harder? I prefer to ask the stupid question and not break something at the firewall. Thanks!
