French Import
zippy_gg's Avatar
First Engine Drop
Must be the season as I see a few threads on engine drops this week.
Anyway here are my questions:
All instructions say to disconnect the fuel lines. I found and disconnected them from the fuel filter (no accumulator on my 86). What other fuel lines do I need to disconnect before the engine drop?
Do I also need to disconnect hose #34?
Thank you Gerry for the picture.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 10-31-2012, 02:41 PM
kodioneill's Avatar
Do a partial engine drop and you'll see what needs to be disconnected.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-31-2012, 02:51 PM
French Import
zippy_gg's Avatar
Hmm... I expected more detailed from those with same model/year car.
I will be doing this drop solo with a jack so I'll have to be careful about balancing the engine while slowly lowering it (instead of dropping ).
Gilles & Kathy
Old 10-31-2012, 04:29 PM
sjf911's Avatar
There are only 2 fuel hoses that need to be disconnected. The first is the high pressure supply line that exits the fuel filter and the second is the low pressure return line that hooks up at 11a. 34 does not need to be disconnected unless you are going to remove the MAF and intake elbow before engine drop.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 10-31-2012, 04:40 PM
audi's Avatar
I did mine solo as well; a little off-topic but I found it less nerve-wracking to lift the car off the motor than drop the motor from the car. I used 3 jacks (had 2, borrowed one), one on each side's jack pad, and a third to help keep the nose of the transmission centered in the tunnel until the rear was high enough to pull the motor straight back and out.
If your motor's up in the air balanced on one jack and it gets wobbly, and you're by yourself, there's little to do but get out of the way...
However you do it, go slow and keep an eye out for anything still connected or that got hung up as you separate the car and motor. Anything you missed or forgot to disconnect will be pretty obvious.
Good luck!
Audi
88 911 coupe felsengrünmetallic/graugrün
86 911 coupe silbermetallic/weinrot - gone but not forgotten
99 Boxster - gone but still in the family
Old 10-31-2012, 05:54 PM
fbeatty's Avatar
zippy_gg, sjf911 is correct. There are only the 2 fuel lines to disconnect. The others you have marked can stay connected.
Just go slow with the jack. Make a platform to give it more width if you can and it will stabilize things out.
Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium and Strontium 90)
08 Cayman, 88 911 Targa, 93 MR2 Turbo, 2012 Jeep JK
Old 10-31-2012, 07:05 PM
Recent emgine drop........
Four weeks ago, I dropped the engine of '87 Carrera to inspect the clutch disc and disconnected the following:
Delivery fuel line
Return line
Brake booster vacuum hose
Disconnected 3 electrical plugs left side of engine and 4 on top of the egine
Ground wires left side
14-pin connector
Ignition coil cable
Hose behind air box
2 hoses from throttle body going to the right side of engine bay
Square connector behind engine (center left)
CV joint
S-hose
Oil line to aux. thermostat
A/C
transmission linkage (tunnel)
clutch cable
starter cable
transmission ground strap
accelerator linkage
speedometer wire from sensor
sway bar
engine breather hoses
disconnect batter cable
And a few things that I forgot........
Tony
Old 10-31-2012, 07:06 PM
French Import
zippy_gg's Avatar
For clarity sake, the items in purple are the lines to be replaced once the engine is out of the car. I borrowed a picture posted by Gerry to try and identify the fuel lines I need to disconnect for the drop.
I tried disconnecting 11a but that little bugger is really tight...
Is the brake booster line represented in the diagram? I thought it was 34 but was corrected earlier.
Gilles & Kathy
Old 10-31-2012, 07:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Just at fuel filter ;-)
I'm in the valley allot. Pm me if you need a hand or moral support.
Jim
'85 Carrera Targa
PCA/POC
Old 10-31-2012, 07:55 PM
French Import
zippy_gg's Avatar
Jim
I understand all that comes at a price.... Good thing I keep Stella in my fridge! Let's chat!
Gilles & Kathy
Old 10-31-2012, 08:53 PM
fbeatty's Avatar
Draco has offered me suggestion in the past that have helped. Good to see you have him close by for support.
Old 10-31-2012, 09:07 PM
French Import
zippy_gg's Avatar
Thanks to Jim (Draco) who came by this morning my engine is now on the floor.
After separating the tranny from the motor we checked the clutch and found it was worn down to the rivets on the flywheel side. Time for new Sachs parts!
The original Boge rear shocks were toast.
Next the banana arms come off for new polybronze bushings...
Oh yeah... I am just Jim will post the mandatory "jack in the box" picture he took of me in the engine bay...
Gilles & Kathy
Old 11-03-2012, 07:40 PM
DRACO A5OG's Avatar
Mais Bien Sur,
'85 Carrera Targa
PCA/POC
Old 11-03-2012, 07:51 PM
fbeatty's Avatar
Congrats zippy_gg, let us know when you get it back together.
Old 11-03-2012, 08:09 PM
French Import
zippy_gg's Avatar
You bet Fbeatty! But it may take a while as I am replacing all suspensions and brake components, and some electrical work.
I'll update this thread as I make progress.
Gilles & Kathy
Old 11-03-2012, 08:16 PM
fbeatty's Avatar
Cool, keep in touch. I have to get the bell housing on my transmission fixed so I am in the same boat. It is going to be a while
Old 11-03-2012, 08:42 PM
No sleep 'til... BROOKLYN
flatsixjunky's Avatar
Bien joué zippy
Take care
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 11-04-2012, 03:17 AM
pensacola mike's Avatar
Looking great! Keep us informed and lots of us pictures too
1987 911 Carrera
Old 11-04-2012, 04:52 PM
French Import
zippy_gg's Avatar
Removing the rear wheel bearings is a real joy...
Driver side
Passenger side
Gilles & Kathy
Old 11-04-2012, 08:47 PM
2porscheguy's Avatar
Subscribed!
Gilles, je vais te joindre bientot. Je suis dans le meme bateau!
I'm planning my first engine drop sometime this winter, so please keep us posted Zippy!
Alex
Alex
'80 911SC Targa
'06 997 C4S Coupe - SOLD
'07 997TT Coupe
Old 11-08-2012, 03:12 PM
