Any more planking pics?
Subaru-powered 912? Looks like there is plenty of room in there for a turbo! :)
definitely enough room for a turbo. I contemplated the idea, but was worried about how much horsepower the 901 gear box could handle, besides the NA 2.5 makes about 200hp with the stinger ecm and pulls great off the bottom end, no turbo lag. It's pretty crazy how light the Subaru motor is compared to the 1.7 914 motor that was in the car when I got it. I plan to have it weighed soon just to confirm how much weight has been shed so far.
Oh Snap! :D
Will these do? http://forums.pelicanparts.com/uploa...1351920517.jpg http://forums.pelicanparts.com/uploa...1351920531.jpg http://forums.pelicanparts.com/uploa...1351920601.jpg |
That's the route I have planned. Subaru gearbox and motor :) Can trim even more weight off car cause the modified transmission is supposed to weigh less then a 915. |
Just had the car weighed today at the dump scale (note sure how accurate it is)
Weight: 2080lbs 1967 912 full tank of gas subaru EJ25 fiberglass bumpers 4 point roll bar 16" wheels RS door panels and carpet Three gauge dash dash pad removed and using plastic cap only radio and glove box removed all ducting and wiper system removed I am not sure if that is considered light or not, I thought the curb weight of a 912 was around 2200lbs, and I thought I removed more than 120lbs, maybe not. Would you guys consider 2080lbs to be light? |
Very cool Hot Rod you've got there.
Dean |
You have added weight back to car because of the bigger/heavier tires and wheels. If you weight them off the car you could post. also, it would be helpfull to see front axel weight and rear axel weight for sway/torsion bar size. good luck Henry
Blow through about 1/2 tank of gas and save 8 lbs/gallon., then subtract from 2080. The more fanatical among us might weigh theirs with only have 3 gallons of fuel and remove the spare, jack, handle and tool kit before weighing. Of course, all this weight savings can be offset by one's own set of personal baggage. Sherwood |
I'd say with that weight 19 and 23 anti rolls are overkill.
Scott |
S |
You might want to look at the post I responded to again. Scott |
Sherwood |
| All times are GMT -8. The time now is 11:02 AM. |
