Chuck Moreland's Avatar
Compression tester, what type?
I have an old compression tester with a flex hose between the dial and the threaded fitting. No way it is going to screw into the 911 spark plug holes due to the deep plug sockets.
What kind of tester works and where to buy?
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-14-2002, 07:35 AM
Talonz82's Avatar
Good question, I've been looking for a factory made product myself, I have a really nice *Mack*, but as you mentioned it had a flex hose, I had to take it to a machinist whom made me a stainless steel tube out of 4140 which the gauge screwed into then he made me a brass fitting for the other end in the exact specs of the original for the spark plug hole
I use this for my leakdown tester (JC whitney) as well.
Old 06-14-2002, 08:11 AM
You want a leakdown tester of the sort that are used to test the compression of lightplane engines, not a plain old compression tester.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 06-14-2002, 08:44 AM
Talonz82's Avatar
Stephan, if that reply was for me, I should have said,
"I use this adapter for my Mack compression tester *AND* for my leak down tester, that I bought at JC whitney."
sorry for the slip...
Peter
Old 06-14-2002, 08:46 AM
jkeyzer's Avatar
The flex hose versions available at Sears et al. will work with some skill and patience, believe it or not. I've done it before and by the end I had gotten the hang of threading the tube in blindly.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 06-14-2002, 09:50 AM
Team California
speeder's Avatar
I would say that a snap-on, (or equivalent), with detachable hose should work fine. The hose is just stiff enough, but flexes enough to meet the plug-hole.
Denis
Old 06-14-2002, 12:20 PM
1-6-2-4-3-5
Send a message via ICQ to zuffenhausen Send a message via AIM to zuffenhausen
Check into the gauges made by Tavia. Very nice.
-zuff
Old 06-14-2002, 12:27 PM
For those of us who are inept at putting a flacid tube in a hole, is an extention such as the one described by Talonz82 available commercially? I was all hyped about doing a compression check and picked up one up. When I went to do the check, I realized the errors of my ways.
Old 06-14-2002, 12:33 PM
Early_S_Man's Avatar
Porsche Crest
Paul,
Such an adapter ... typically called an 'air holding chuck' must be available by now from suppliers such as Lisle ... for the Ford modular V-8 SOHC engine, and its' plugs are even further recessed than a 911's.
For those with oxy-acetylene rigs, it probably wouldn't take more than an hour to make one from an old spark plug, scrap of iron 3/8" pipe, and suitable fitting.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-14-2002, 01:20 PM
Hilbilly Deluxe
emcon5's Avatar
Paul, you know they hava a pill for that now, right?
Tom
82 911SC Coupe
GTI Cup #43
Old 06-14-2002, 01:50 PM
Chuck,
If you're doing compression tests for a living, get the Snap-On (or equiv.). If not, the Sears two-piece (detacheable hose) compression tester works fine (at least the one I have). I suppose the Sears return policy gives you an out if it's not easy to use. The price difference buys a lot of brewskis.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 06-14-2002, 03:17 PM
Turns out I'm better at putting floppy hoses down tubes than I thought. I am happy to say I have no similar experiences to draw upon.
Based on above comments I gave the old tester a try and it works pretty easily.
I've worked a deal on a '73 coupe. I'll be checking head studs and compression on the motor tomorrow AM. If all is in order we close the deal.
Old 06-14-2002, 04:06 PM
