El Duderino
tirwin's Avatar
Double sided tape for 3rd brake light?
I installed a Hella 3rd brake light when I put in a new headliner. The double sided tape that came with it didn't hold so I bought some 3M brand tape. It didn't hold either. What am I missing here? Is there any particular brand that is better than the others? This shouldn't be this hard.
Old 11-04-2012, 04:58 PM
super glue
Old 11-04-2012, 05:12 PM
Danny_Ocean's Avatar
If you're going to use tape, look for "trim tape". It's used to hold trim on cars. It will hold your light.
Old 11-04-2012, 05:28 PM
El Duderino
tirwin's Avatar
I don't think glue will work. The surface of the outer lips is channeled a little bit where the tape is supposed to go so I'm not sure there is enough surface area to come in contact with the glass. Have you done it or was it just an idea? If you've done it then I'll give it a go.
Old 11-04-2012, 05:29 PM
El Duderino
tirwin's Avatar
Ah. I'll go to my FLAPS and look for it. Thanks!
Old 11-04-2012, 05:31 PM
An auto body supply house will have it if you can't find it at the parts store.
Old 11-04-2012, 05:39 PM
I have had the best luck with 3M VHB tapes. This double sided tape is the best! For best results you do have to clean the surfaces with alcohol before you use the tape.
Old 11-04-2012, 05:44 PM
was just an idea. but if it wont sit tight without the tape maby you can put the super glue right on the tape.
Old 11-04-2012, 05:49 PM
ROW '78 911 Targa
timmy2's Avatar
My mirror is mounted using the iphone 3m tape they use to mount the digitizer to the glass.
Hasn't moved in a year.
About 50 cents or less on ebay. Throw away the outer part that is cut to fit the phone and trim the remainder to the right size.
Edit: Just looked at the piece I cut off, the label says it's 3m 200MP tape
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-04-2012, 07:47 PM
Do NOT use super glue....
Old 11-04-2012, 07:53 PM
Diss Member
Quicksilver's Avatar
Superglue isn't a panacea.
+1 on the 3M VHB. If it doesn't pull the paint off then the surface isn't clean enough.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-04-2012, 10:19 PM
