What the Fuchs?
OK I'm looking at getting some fuchs for my 1969 911 E.
I was thinking about getting 16 by 6 for the car. What is a reasonable amount I should pay for a set of 4? I'm not hung up on getting a set of 15 by 5.5 that cost an insane amount. |
Joe is that in driving condition?
IMO, 16" wheels (especially) 16X6 look terrible on an early car. If you want a better set of wheels on they cheap I'd reccommend 15X6 ring-type center cap wheels. These can be had in driver condition for about the same price.
Just my $0.02 Good luck with your search.
1973 Coupe Projekt X (AKA bunch o' boxes full of parts) |
I usually pay no more than $250 per wheel. Sometimes as little $150.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
The advantage of 16" wheels is that you you can use lower aspect ratio tires(50 or 55) and have the same height and widths. I don't think they look that bad.
69 911 2.3Ez 85 928S |
![]() With stock torsion bars I delevoped a rear inner fender rub. After consultation with Jeff Gamroth (Rothsport Road and Race) and Steve Weiner I went to Turbo T-bars (21 mm front/26 mm rear) to reduce squat and roll. I had Rothsport do a decent lower/align/corner balance during which they discovered a bent banana arm (which was replaced). I no longer have any more issues.
Home of the Whopper
I don't think the 16s look bad, but 15s definite look better imo. Flat 6s aren't too expensive.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
OK, I think I will go for 15" then.
Suggestions on places to pick them for a good price. Feebay seems like they are high. |
Is 1500 bucks way out of line for deep 6"s with hearts?
Depends on condition. If they're drivable, that's a fair price.
OK, the wheels are not deep 6" the are for a 76 car, but the wheels are very drivable.
I have a 1969 is getting deep 6 critical or not? |
$1500 for '76 dated 6" wheels is on the high side unless they are PERFECT (never installed perfect).
Deep 6 wheels are correct for a '69. They are only important if you want period correct wheels. If not, any 6X15 Fuchs is going to fit and work on the car. |
OK cool, I will wait for a better deal. They are not perfect I will let them pass then.
Good luck with your search. For quick reference, wheels dated prior to '73 are going to be worth more than post-'73. The earlier wheels take 3-prong center caps and are more desirable, but otherwise all 6X15 Fuchs are the same quality and spec.
OK need some advice, 14 by 5.5 what about those?
Home of the Whopper
That's what was stock on my 71e targa.
Caveman Hammer Mechanic
Here ya go:
porsche 911 fuchs
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
OK, thanks for everyone's input.
I picked up a set of 4 14 by 5.5s for about a grand. They need to be refinished but they look to be in good shape. Two are 1969's like my car one is 1968 the other is a 70. Still when I get them done and the guy I'm using is very good with Fuchs they should be worth 2000. Does that sound about right? |
Came on 911Es as part of the "comfort" package, also came on the 914-6 & 76 912E. They would be fine.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
i have 4 NOS 14's, when the perfect original parts are needed, make a ridiculous offer
Damon @ SERIES 900.com Sunapee NH several 911 variants |
