-   -   What the Fuchs? (http://forums.pelicanparts.com/porsche-911-technical-forum/714962-what-fuchs.html)
Eli W 11-04-2012 05:43 PM
What the Fuchs?
OK I'm looking at getting some fuchs for my 1969 911 E.
I was thinking about getting 16 by 6 for the car.
What is a reasonable amount I should pay for a set of 4?
I'm not hung up on getting a set of 15 by 5.5 that cost an insane amount.
Eli W 11-04-2012 06:27 PM
Joe is that in driving condition?
kugelfischer 11-04-2012 06:41 PM
IMO, 16" wheels (especially) 16X6 look terrible on an early car. If you want a better set of wheels on they cheap I'd reccommend 15X6 ring-type center cap wheels. These can be had in driver condition for about the same price.
Just my $0.02
Good luck with your search.
j911brick 11-04-2012 06:44 PM
I usually pay no more than $250 per wheel. Sometimes as little $150.
jstobo 11-04-2012 06:52 PM
The advantage of 16" wheels is that you you can use lower aspect ratio tires(50 or 55) and have the same height and widths. I don't think they look that bad.
http://forums.pelicanparts.com/uploa...1352087509.jpg
HarryD 11-04-2012 07:20 PM
Just my $0.02
Really? I like how my car looks with 16x6 Fuchs and 205/55-16 tires:
http://forums.pelicanparts.com/uploa...1257378612.jpg
With stock torsion bars I delevoped a rear inner fender rub.
After consultation with Jeff Gamroth (Rothsport Road and Race) and Steve Weiner I went to Turbo T-bars (21 mm front/26 mm rear) to reduce squat and roll. I had Rothsport do a decent lower/align/corner balance during which they discovered a bent banana arm (which was replaced). I no longer have any more issues.
BK911 11-05-2012 03:48 AM
I don't think the 16s look bad, but 15s definite look better imo. Flat 6s aren't too expensive.
Eli W 11-05-2012 05:40 AM
OK, I think I will go for 15" then.
Suggestions on places to pick them for a good price. Feebay seems like they are high.
Eli W 11-06-2012 06:33 AM
Is 1500 bucks way out of line for deep 6"s with hearts?
kugelfischer 11-06-2012 06:36 AM
Depends on condition. If they're drivable, that's a fair price.
Eli W 11-06-2012 07:19 AM
OK, the wheels are not deep 6" the are for a 76 car, but the wheels are very drivable.
I have a 1969 is getting deep 6 critical or not?
kugelfischer 11-06-2012 07:25 AM
$1500 for '76 dated 6" wheels is on the high side unless they are PERFECT (never installed perfect).
Deep 6 wheels are correct for a '69. They are only important if you want period correct wheels. If not, any 6X15 Fuchs is going to fit and work on the car.
Eli W 11-06-2012 07:37 AM
OK cool, I will wait for a better deal. They are not perfect I will let them pass then.
kugelfischer 11-06-2012 07:52 AM
Good luck with your search. For quick reference, wheels dated prior to '73 are going to be worth more than post-'73. The earlier wheels take 3-prong center caps and are more desirable, but otherwise all 6X15 Fuchs are the same quality and spec.
Eli W 11-07-2012 08:13 AM
OK need some advice, 14 by 5.5 what about those?
BK911 11-07-2012 08:36 AM
That's what was stock on my 71e targa.
ClickClickBoom 11-07-2012 08:43 AM
Here ya go:
porsche 911 fuchs
Eli W 11-07-2012 10:44 AM
OK, thanks for everyone's input.
I picked up a set of 4 14 by 5.5s for about a grand. They need to be refinished but they look to be in good shape.
Two are 1969's like my car one is 1968 the other is a 70. Still when I get them done and the guy I'm using is very good with Fuchs they should be worth 2000.
Does that sound about right?
Racerbvd 11-07-2012 10:44 AM
Came on 911Es as part of the "comfort" package, also came on the 914-6 & 76 912E. They would be fine.
Series900 11-07-2012 10:50 AM
i have 4 NOS 14's, when the perfect original parts are needed, make a ridiculous offer:rolleyes:
