-   -   shifter question ( spacer under shifter ) (http://forums.pelicanparts.com/porsche-911-technical-forum/714976-shifter-question-spacer-under-shifter.html)
carl74344 11-04-2012 07:56 PM
under the shifter holding the mounting for shift rod bushing. there is a spacer between the sifter houseing and the mount for the shift rod bushing. is this normal. i.ve replaced all the bushing. still am having shifting problems. sometimes shifts into 1 st just fine most times not. i adjusted the shift coupler had no play in 5th gear. now all gears are stiff but 1st hard. seems the first shift of the day is good. also replaced motor mounts. not sure what to do.. thanks carl
deshetlr 11-04-2012 08:07 PM
No spacer in my '86.
timmy2 11-04-2012 08:40 PM
Sounds strange, post a picture of the spacer and the location if you can.
carl74344 11-04-2012 09:29 PM
can not post pic as it is back together. at the rear of the shifter there are two bolts that hole shifter down under that is the floor , spacer , then the bracket that holds the shift rod bushing. this is the spacer I'm talking about, thanks 1982 911sc
OZ930 11-04-2012 09:47 PM
No gasket in 1981 and confirmed in the parts the catalogue
http://www.porsche.com/all/media/pdf/originalparts/en/E_911_83_KATALOG.pdf
timmy2 11-04-2012 10:11 PM
I didn't have a spacer in mine when I re-did all of my bushings this spring.
proffighter 11-05-2012 12:53 AM
If the spacer looks like this on the right, then you have a short-shift kit mounted
http://forums.pelicanparts.com/uploa...1352105610.jpg
OZ930 11-05-2012 03:04 AM
Weltmiester kit
cdrik915 11-05-2012 04:43 AM
+1.
I had the same spacer in my car.
Weltmeister kit .
It's a short shift set.
ivangene 11-05-2012 05:15 AM
weltmeister
https://encrypted-tbn2.gstatic.com/i...lV3WqJvaNuop0q
some of them are plastic (poor plastic that cracks)
OZ930 11-05-2012 01:03 PM
http://forums.pelicanparts.com/uploa...1352148709.jpg
I agree with you Ed that what you have pictured is a Weltmiester, but I have found this kit also listed as a Weltmiester ???
I wont mention the supplier here to avoid conflict with PP.
Cheers
proffighter 11-05-2012 03:38 PM
The one without spacer plate is for a 4-speed 930 tranny, like the one I posted...
