carl74344's Avatar
shifter question ( spacer under shifter )
under the shifter holding the mounting for shift rod bushing. there is a spacer between the sifter houseing and the mount for the shift rod bushing. is this normal. i.ve replaced all the bushing. still am having shifting problems. sometimes shifts into 1 st just fine most times not. i adjusted the shift coupler had no play in 5th gear. now all gears are stiff but 1st hard. seems the first shift of the day is good. also replaced motor mounts. not sure what to do.. thanks carl
1982 guards red 911 sc work in progress
Old 11-04-2012, 07:56 PM
deshetlr's Avatar
No spacer in my '86.
Old 11-04-2012, 08:07 PM
ROW '78 911 Targa
timmy2's Avatar
Sounds strange, post a picture of the spacer and the location if you can.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-04-2012, 08:40 PM
carl74344's Avatar
can not post pic as it is back together. at the rear of the shifter there are two bolts that hole shifter down under that is the floor , spacer , then the bracket that holds the shift rod bushing. this is the spacer I'm talking about, thanks 1982 911sc
Old 11-04-2012, 09:29 PM
No gasket in 1981 and confirmed in the parts the catalogue
http://www.porsche.com/all/media/pdf/originalparts/en/E_911_83_KATALOG.pdf
Old 11-04-2012, 09:47 PM
ROW '78 911 Targa
timmy2's Avatar
I didn't have a spacer in mine when I re-did all of my bushings this spring.
Dennis
Old 11-04-2012, 10:11 PM
proffighter's Avatar
If the spacer looks like this on the right, then you have a short-shift kit mounted
Roland
930 Turbo '81 Too many modifications to list
Old 11-05-2012, 12:53 AM
Weltmiester kit
Old 11-05-2012, 03:04 AM
cdrik915's Avatar
I had the same spacer in my car.
Weltmeister kit .
It's a short shift set.
LIGHTER = FASTER !!!
Old 11-05-2012, 04:43 AM
ivangene's Avatar
weltmeister
some of them are plastic (poor plastic that cracks)
Ed M
86' Coupe
Old 11-05-2012, 05:15 AM
I agree with you Ed that what you have pictured is a Weltmiester, but I have found this kit also listed as a Weltmiester ???
I wont mention the supplier here to avoid conflict with PP.
Cheers
Old 11-05-2012, 01:03 PM
The one without spacer plate is for a 4-speed 930 tranny, like the one I posted...
Roland
Old 11-05-2012, 03:38 PM
