Engine Tin Question
Can someone clarify why the driver's side piece may or may not have a hole in it, depending on the part number? The part w/ the hole apparently come w/ a cap as well...
Thanks. |
Depends on year of the car. Early cars had a hole on each side for heat hose pass through. Later cars 77 on had a blower motor in the engine compartment that changed the configuration of the heat system. After that there were subtle changes.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
So its for a heater hose? Thanks. My '81 has the blower motor, which is why the original part I'm trying to replace doesn't have a hole...
