need sheet metal replacement parts
Hello all
I am looking for a good source for used sheet metal for my 79 911sc'
Need a rear cross member latch panel, the one the engine hood latches to.
Restoration design has them for 700.00 Hate to spend that when I only need a partial.
so if anyone could suggest a re seller of used parts I'd appreciate it
Old 11-06-2012, 03:57 PM
300hp 1800lbs is the goal
pksystems's Avatar
Check the used parts section.... there's usually someone cutting up a tub in that section
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 11-06-2012, 04:01 PM
