thebondman's Avatar
Send a message via ICQ to thebondman
Question How do you adjust the hand brake light switch? Also,where is it?
I have been having problems with the hand brake moving slightly and the "Brake" light coming on. I move the handle a little and the light goes out. I now have the cover off. Can someone give me some insight on what to adjust so the light goes off properly. Thanks,
BILL
P.S. HURRY, I'm putting in different seats.
"If you're not living on the edge, then you're taking up too much space."
My 1979 930
1979 930- 3.4L Andial Racing P/C's/Fuel Enrichment System/Adjustable Boost Control,Euro Fuel System,Group B Cams,K27 Turbo(1.0 Bar) Andial Intercooler, GHL Muffler/SS Header Sys,Welt. SS Kit/Camber Brace, SS Brake Lines, 350mm Momo, Billet Pedals, 9x17 - 11x17 Fikse.
1999 FXSTC- Harley Davidson HI-4 Ignition,Thunderball Cam,Mikuni 42mm,Vance & Hines
2003 Jetta Wagon GLS 1.9L TDI
1993 GMC Jimmy 4x4
St. Louis PCA - Member
Kirkwood H.O.G. Chapter #2573 - Member
Gateway H.O.G Chapter #1337 - Charter Member
Old 06-19-2002, 10:22 AM
Senior Member
Jdub's Avatar
You should see a small screw on the side of the twin heater lever assembly and a slot in which the switch can move. I used a dime to turn the screw as there is very little room for a screwdriver. Loosen the screw, put the brake at its natural "off" rest point, and then (with ignition on) move the switch until it just goes out. Tighten down and test again.
John
'78 Targa in Minerva Blue
Old 06-19-2002, 10:39 AM
thebondman's Avatar
Works great, thanks.
BILL
My 1979 930
1993 GMC Jimmy 4x4
Old 06-19-2002, 01:12 PM
