-   -   2.7 engine noise (http://forums.pelicanparts.com/porsche-911-technical-forum/716809-2-7-engine-noise.html)
tzkev 11-14-2012 01:51 AM
2.7 engine noise
I have a odd engine sound that hopefully someone is familiar with. The engine has the late tensioners fitted so Id possibly rule tensioners out.
911 2.7 engine noise - YouTube
Thanks in advance.
Kev
Bob Kontak 11-14-2012 02:57 PM
For some reason the link you provided does not connect with youtube - says the address was misunderstood. So I loaded in the title and I think this is the correct link.
When was the tensioner update performed? The noise does not sound deep and it sounds like a chain slipping. Kinda-sorta.????
redstrosekNic 11-14-2012 07:04 PM
Thanks in advance.
Kev
When you say "late tensioners", do you mean presssure fed tensioners?
tzkev 11-15-2012 12:41 AM
Yes, they are the pressure fed type.
Kev
