winter
Winter's Avatar
Originally Posted by 86911tlcab View Post
You can reach into the socket with a small tool and bend the two metal pieces toward you...I did the same thing and it worked fine. they will then press up against the light bulb..
I literally just did this “repair” this morning. I was attempting to figure out why my front rt. turn flasher wasn’t working, noticed that my rt. rear taillight was not illuminating, the bulb looked fine, but was loose and not contacting the metal tabs in the housing, pulled the tabs out with a small pick and now the taillight works as it should, as well as my front flasher.
It was nice to have the fix be so simple, and a good reminder to check that all bulbs are making correct contact in their housings before going deeper and pulling things apart.
Tom
'76 Targa
Old 07-05-2025, 02:08 PM
Do the lights work with the hazard switch?
Old 07-05-2025, 05:32 PM
kevbo's Avatar
Hi Zuch, yes the hazards work along with the brake lights. Just the right front and rear "marker" lights don't work. Thoughts?
Kevin
1986 Carrera Targa
Old 07-06-2025, 03:22 AM
Originally Posted by Hotwatermusic View Post
My passenger side rear taillight is out--both parts, rear and side. Turn signal and brake lights work though. The bulb filament looks good though. What would cause just my passenger side rear tail light to be out? 1974 911
Thanks!
Canton police.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 07-06-2025, 05:10 AM
kevbo's Avatar
Removed the headlight switch. This wiring concoction (thin red line trace) seems interesting for the right-side lighting... Thoughts other than calling the Canton police?
Kevin
1986 Carrera Targa
Old 07-06-2025, 07:19 AM
