derek murray's Avatar
searching for licence plate light wires
Where do the brown and grey wires for the rear licence plate light enter the engine bay?
The wires are still in the rear deck lid (cut off at the hinge) but I cant find anything to re-connect them to. Obviously the brown wire (earth) is not such a big deal... but I need that grey one!
By the way, the grey wire is present at the switch.
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 06-18-2002, 10:58 AM
Early_S_Man's Avatar
Porsche Crest
Derek,
That wire comes directly from the main wiring harness prior to the 14-pin connector ... so it should be coming out along the left side of the engine compartment forward of the relay/fuse/regulator panel, and go upwards toward the lid ... but, the sound insulation pad may interfere with access in that area!
Here is the wiring diagram:
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1971_Part-1.jpg
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-18-2002, 11:52 AM
