Fog light issues
Hi folks,
I've recently taken ownership of a 1984 RoW 911 targa. I bought the car knowing there was an issue with the fog lights and was pretty sure I could get to the bottom of it. Well..... please help. When I pull the headlight knob to the 1 st position, the fog lights come on regardless of the position of the fog light knob. When I pull the headlight knob out to the 2nd position the fog lights will not come no matter what position the fog light knob is in, high beam, low beam, etc. Does this type of behaviour sound familiar? From reading other posts I'm thinking the problem is the hi-beam/low-beam/turn-signal switch. Any thoughts? Also, when looking at the wiring under the dash I saw this black box with an image of a headlight on it dangling from the wiring. Is this normal/stock? Thanks in advance |
SOunds like someone has made them into daytime running lights.
Better get the wiring schematic and trace everything out. Draw yourself a picture and go from there. |
Here's a pic of the dangling box I mentioned.http://forums.pelicanparts.com/uploa...1353210260.jpg |
The NA diagram for my ROW car has been correct. Do you have the Bently for your car?
I have no idea what your black box is. Perhaps a replacement for something that broke or a relay kit just for the fogs? I don't have fog lamps on my car but the wiring shouldn't be too complex. There aren't any unknown switches on the dash are there? |
Pelican has this diagram posted.
http://forums.pelicanparts.com/uploa...1353218131.jpg |
In my 84 ROW the fog lights only work if the headlight switch is in the first position, then using the fog light switch I can operate the fog lights. If the headlights are in the second (on) position the fog lights turn off and the healights go on.
In this thread are a few useful comments by Canada Kev regarding the wiring of the euro foglights. http://forums.pelicanparts.com/porsche-911-technical-forum/394201-can-i-wire-rear-fog-front-fogs-w-out-frying-my-system-2.html |
On my 89, the fogs will come on in the first postion (as long as asked to do so),..and will remain on with low beam headlamps being on....the fog lamps cut off when I go to Hi-beam switch setting...... just an FYI, from the 1989 world.....
BEST! Doyle |
Pelican Parts - Porsche 911 Parts Listings & Diagrams |
| All times are GMT -8. The time now is 04:29 AM. |
