adjusting mfi pump?
does anyone know how to correctly adjust the mfi pump? i see our host sells a few tools to adjust the pump. is it something i can do? im ok with motors. definitely not an expert. i can take it to my porsche mechanic, but i would like to learn how to adjust it correctly. thanks
Old 11-18-2012, 04:46 AM
Crusty Conservative
silverc4s's Avatar
You need to read the Factory Manual entitled Check, Measure, Adjust for the MFI System. I believe that a scanned copy is available online. Do a search and you will find it. Good luck, and have a lot of patience...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 11-18-2012, 05:09 AM
tharbert's Avatar
Start reading here.
Then, read all of this.
Most importantly: CMA2
The short answer is, tune up the engine first. Normally, MFI pumps are set for a motor in factory spec. About the last thing you want to do is start adjusting a pump for a motor that isn't otherwise running right.
You'd probably be better off describing your problem here once you've gone thru CMA2. There are some genuine MFI experts in this forum...me not being one of them.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-18-2012, 06:36 AM
