Transmission fluid for 89 g50 carrera
Has anyone had experience with Brad Penn 75-90 fully synthetic gear oil or the Royal Purple 75-90? I went to look to see what the local autozones had and all they carried was the Mobil1 75-90 LS and the Royal Purple 75-90. I was amazed that the Royal Purple was about $18/quart and the the Mobil 1 at $10. Any suggestions? I did go back and read the info on the Trans fluid and seems the consensus was the Mobil 1. Thanks for any suggestions. I am using the Swepco 201 in the 901/911T. Steve
Steve 1970 911T SOLD 1989 3.2 Carrera 2013 991 Carrera S |
muck-raker
Mobil1 Delvac. Can be purchased from Charles Navarro's website. Recommended for the G50 by a strong majority. Don't know anything about the BP gear oil, but I've heard of several using Royal Purple and being happy with it. I don't think you could really go wrong with any of 'em.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Kendall Super Three Star Full Syn 75W 90.
Keep the Shiny Side UP! Pete Z. |
Easily Confused
Kidrock,
Curious as to what part of West Texas you are in. I grew up in Midland and get back there on a semi-regular basis.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
M1Delvac....
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
muck-raker
dtxscott, I'm in Hell Paso. Just here as part of my employment.
My 89 G50 has been very difficult getting into first whenever it was not fairly warm, and after researching on Pelican, I changed to Kendall Gear Oil API GL-5 SAE75w-90 with limited slip additive (three star I believe). The shifting ease is remarkably better with Kendall--no doubt about it and I wish I had the knowledge to change out the fluid a year ago (3,500 miles ago) when I acquired the 911.
muck-raker
Spiderman
BP in my G50
I have it in mine, seems to work fine. All the "spec" numbers are same as the kendall as I remember. Using the 75-90 fully synthetic hypoid gear/blower racing lubricant as its called. Part number is 7766-023 in quart bottles.
I have no reference points for whats "better". I may change over to the kendall this winter and see if I notice any difference after 2 years with BP. My second gear is a bit difficult after 200k + miles if I don't double clutch so would be interesting to see if that improved. I've got a Brad Penn distributor close by but they couldn't get quart size gear oil. I bought mine via Amazon as about 50% more money for 4 quarts. Quarts of reg. BP racing motor oil are amazingly in-expensive there (much better than discount stores).
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
I used both the RP max gear and Delvac and will be going back to RP. The Delvac feels like it takes forever to warm up and the 1 -2 shifts are brutal, like shifting a semi in the morning. The RP is much more forgiving and my G50 felt more relaxed with it.
I have not tried the Kendall oil yet. |
muck-raker
so where can a mere mortal acquire this magical elixir known as Kendall 3 Star???
gearhead
I do not recommend Delvac for anything but track driven vehicles. It contains none of the friction modifiers that you find in the factory fill PTX Mobilube. Delvac is a phenominal track oil with great high temperature properties. But it is thick and sticky when cold.
Any of the oils being discussed are acceptable oils for your G50. I refrain from engaging in the great gear oil debates and refuse to name any one single oil the "best" or just endorse an oil. Personally, I run Swepco 201 in my daily driver. It is not a G50, but it has Borg Warner synchros just like one. I've never understood why people say you cannot use Swepco in a G50. Lots of my customers use it in their G50s and their 944s, many of them in racecars. I see no issue there. Regards, Matt Monson Guard Transmission LLC
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
On Tour
Kendall Syn G50 Gear Oil- Which One Is It? - Rennlist Discussion Forums Thoughts? So we are really looking for the Brad Penn product now?
- 2018 Cayenne S 958.2 - 1988 Carrera 3.2 Coupe Marine Blue (SOLD) |
I used this "Kendall 80W-90 GL-5 NS-MP Hypoid Gear Oil" from our host this summer. Shifts nice once it's up to temperature. A little notchy when cold but warms up pretty quick. No complaints here. (146k on tranny for reference).
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
