PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Question How to install 993 door handles on early 911?
I tried searching... but could not find a thread with step by step on how to do this swap.
Anyone that can share the process? Am I doing this correctly?
Top barrel is 993, lower one is from my SC ('81)
Cylinder lock shorter for the early 911 as you can see in the photos...
Should I be using only the cylinder lock and end leg?? or just the cylinder lock? I don't see how I can reuse the end leg from the 993, can't bolt it down, unless I get a longer bolt...
Looks like it is the only way this could go together... my old 911 cylinder lock with the end leg from the early handle...
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 11-20-2012, 11:44 AM
wachuko's Avatar
And just for kicks... 993 cylinder lock does not work on the early door handles...can't slide it in all the way.
Drive safe!
1967 - Porsche 912
Old 11-20-2012, 11:56 AM
wachuko's Avatar
Cool
I took the internal apart to get them ready for when the handles are painted. I only have one of the internal parts... still looking for the driver side (WTB thread).
2.5 hex
8mm socket
And it is out... notice the R ... side specific
Drive safe!
1967 - Porsche 912
Old 11-20-2012, 04:28 PM
